So my 5th lexus sc430
2002 13k miles
Battery light is on
Good battery
I took off the negative and positive cable and car still on... I understand if the alternator is bad would car would die... Any suggestions?
2002 13k miles
Battery light is on
Good battery
close
- Join DateSep 2010
- LocationAlberta
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:4,274 Times in 3,585 Posts
Has the battery been load tested? Has the alternator been bench tested? What is the battery voltage with the engine running? Hook up a code reader and find out why your other warning lights are on (probably due to the battery light).
Im cuious if any of the dash lights go out when the battery is disconnected. But the natural and logical evaluation is a bad battery.
Paul
Paul
Quote:
It's a weird thing, but 4 out 5 of my sc430 have theOriginally Posted by Lexus2000
Left warning lights on...
I'll check the battery
Thanks
GmanSC
close
- Join DateOct 2015
- LocationCA
Liked:614 Times in 469 Posts
Your alternator is about going dead. The battery light is on when the alternator voltage drop below the set limit. Do not drive your SC until you have it checked or replaced. You don’t want your SC stranded on the emergency lane of the freeway.
DshngDaryl
close
- Join DateMay 2016
- LocationAZ
Liked:631 Times in 511 Posts
Thanks
If you mean the lights in the left circle of your dash, that means you need to use the paper clip trick.Originally Posted by mirko61
It's a weird thing, but 4 out 5 of my sc430 have theLeft warning lights on...
Thanks
Those lights come on when they use a code reader to check what is wrong with your car.
Go to Google and type in sc430 Paper Clip reset
GmanSC
close
- Join DateOct 2015
- LocationCA
Daryl, his question was regarding to the battery warning light on the right. His alternator is going out.Originally Posted by DshngDaryl
If you mean the lights in the left circle of your dash, that means you need to use the paper clip trick.Those lights come on when they use a code reader to check what is wrong with your car.
Quote:
So i guess I'll replace the alternatorOriginally Posted by GmanSC
(the gray one)
But i liked the answer of the paper clip too, i seen it before on YouTube
Thank everyone
Lavrishevo
close
- Join DateJan 2012
- LocationNJ
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:324 Times in 239 Posts
Quote:
(the gray one)
Thank everyone
Are you collecting them. Why 5?Originally Posted by mirko61
So i guess I'll replace the alternator(the gray one)
Thank everyone
Harold57
close
- Join DateAug 2006
- LocationTexas
Liked:416 Times in 364 Posts
mirko61, we've had a number of folks with 2 SC430s, but it looks like you are the first to have 3! Is that the case?
Quote:
I like them i fix them up, keep rhe one i like the most for a while, then sell them, buying 1 more next week.. 😉Originally Posted by Lavrishevo
Quote:
Actually 5..Originally Posted by Harold57
One black 2005
Pink 2003 with camero exhaust system
Blue 02
Gray 02
Black 02
Looking for the pebble beach 06 now
When I'm finished fixing them I'll sell 2 or 3
Bgw70
close
- Join DateDec 2014
- LocationFl
Liked:949 Times in 756 Posts
Quote:
One black 2005
Blue 02
Gray 02
Black 02
I am surprised you don’t have Techstream and a VSC reset tool. Especially owning so many SC430sOriginally Posted by mirko61
Actually 5..One black 2005
Blue 02
Gray 02
Black 02
VSC reset tool Thread
https://www.clublexus.com/forums/sc4...c430-help.html
Thank you I'll check it out Originally Posted by Bgw70
I am surprised you don’t have Techstream and a VSC reset tool. Especially owning so many SC430sVSC reset tool Thread
I have snap on scanner, but i haven't try it yet
DshngDaryl
close
- Join DateMay 2016
- LocationAZ
The reset tool is the same as the paperclip trick, but much easier.Originally Posted by Bgw70
