It's Mine Now
For me it was the nav motors as well. I ended up sending the original unit out for repair but in the interim I purchased a used unit from eBay and it is still working. My original is still in the box lol. Not that we use it much (mostly use Waze). We keep the nav door closed 99% of the time. If it's better you, pull the door down with your finger so that it stays in the closed position until you figure out what you want to do. At least then the dash looks finished. Looking forward to seeing pics of the car!
the little motors are about $5ea.
Bgw 70
I will get a picture and try and post it. Not today as we are under a winter weather watch. I asked Rick but you might have the same thing on your 07. I have a slot in the black tray where the jack is located on the left/driver side 2nd slot in that is about 8 inches long and it appears something maybe index finger round went in it. Am I missing a part?
Dennis
Dennis
Lexus will provide one free of charge if yours is missing.
Bgw70
Yes that is the place and like you mine is empty. Also the only fuse that I could find for the Nav/TV system is the 5 amp in the #14 slot in the passenger side fuse box? Is this correct? I pulled it and checked it with my amp meter and yes it is good so no joy in mudville.
Dennis
Dennis
Bgw70
Dennis
Dennis
check the Lexus maintenance records and look at all entries prior to her report about the door/tilt problem.
did Lexus do any work in the dash or console?
perhaps, someone forgot a plug.
i am going to provide you with schematics of the system. Check all of those fuses.
You might could call the dealer that worked on it and ask if they could tell you what they found.
Coleroad (12-08-18)
I believe it came standard. I have the same one in our 2010 LS 460L. I opened the one on the SC today. It had never been opened, I cut the wire tie with the round Lexus medallion attached to it off. I added the large size band aids to it (I bleed a lot).
Dennis
Dennis
