SC430 Top problems
Old Feb 7, 2018 | 11:02 AM
VVTiBob's Avatar
VVTiBob
So the DTC B2521 points to the roof close limit switch at the A pillar above the right visor. This switch, along with the one on the left side detects when the roof is closed.
It makes sense if this switch has malfunctioned the roof would not close from its open position in the trunk. Part # 84742-24030 (there are two LH and RH) is a $50 part . FIRST you need to verify this is the correct part number for your VIN. Second are you up to taking apart several trim pieces, overhead light assembly, visor assembly just to gain access to the switch with NO GUARANTEE this is the only problem. Because I don’t understand the bent hinge statement at all.
Finally I suspect your dealer used their software to get the quarter windows up into the closed position.
Old Feb 7, 2018 | 12:42 PM
Caflashbob's Avatar
Caflashbob
Originally Posted by VVTiBob
Here is a diagram of the sliding roof electrical components. Between the DTC and the diagrams we can clarify what we are talking about using the correct terminology.
Ah someone seems to have a shop manual
Old Feb 7, 2018 | 12:49 PM
mikail's Avatar
mikail
Great posts guys, will definitely keep you posted not what I have so much info to go on, many thanks, more to come soon!
Old Feb 7, 2018 | 12:51 PM
mikail's Avatar
mikail
Talking
Yeah I am working on sorting his out with a good mechanic buddy who knows his stuff, these pointers and pictorials will most definitely help.
And yes I think that is how they got the rear windows up as well, but who knows.
Oh boy, here we go!
Old Feb 7, 2018 | 02:11 PM
VVTiBob's Avatar
VVTiBob
One other comment. It’s my understanding DTCs are not stored past a shutdown due to the number of components and ECUs involved with the sliding roof operation. In other words each open and close can generate new DTCs or not if no errors are encountered.
Last comment and should go without saying, ALWAYS disconnect battery before working on any of the electrical components. They are way TO EXPENSIVE to accidentally fry.
Old Feb 8, 2018 | 09:22 AM
DshngDaryl's Avatar
DshngDaryl
Yes, this is an important thing to know. Techstream won't store any codes for the roof module. They only show up when you press the open/close button. I think it is part of the self check before the procedure commences.
Old Feb 8, 2018 | 09:24 AM
DshngDaryl's Avatar
DshngDaryl
As a person who has fixed his top, I can say with confidence, your friend will need a copy of techstream. Do a search in this forum. It is easily accessible and not very expensive. If you have an old computer, you are looking at an investment of $20 or less.
Old Feb 11, 2018 | 02:27 PM
tiguy99's Avatar
tiguy99
Saving this thread for sure. Saw a higher milage SC I was interested in. O.P, please keep us posted on how the repairs go. Hopefully it's an easy fix
Old Feb 11, 2018 | 03:34 PM
JohnnyCake's Avatar
JohnnyCake
Exactly correct. I remember going to the Lexus dealer with an intermittent problem and working out a deal ($$$) just to get the codes. We had to cycle the top a bunch of times before getting a fault. Then they came out, read the code, and buh-bye!
Old Feb 11, 2018 | 10:24 PM
mikail's Avatar
mikail
Hey everyone, big thanks so much for all of the very helpful posts!
Currently I am just working out who is going to actually help me with this repair as I'm not that good with this kind of work, but I have one great mechanic who is trying to deiced if he will take it on, and then a couple of possible Russian techs who might be able to give some assistance with it as well.
Either way I will definitely report back how things go once I get a bit further along.
Old Feb 12, 2018 | 09:57 AM
DshngDaryl's Avatar
DshngDaryl
the problem looks like a B2521 code is tied to the Package tray.
If you were to read this post and print out the PDF's Bob included, you could hand them to any potential mechanic and see if they would want to try and tackle the problem.
https://www.clublexus.com/forums/sc4...not-close.html
Old Feb 12, 2018 | 05:58 PM
VVTiBob's Avatar
VVTiBob
No, B2521 is a switch (RH side) for the roof close at the A pillar. But if 2518 does come up during a future roof movement, then that old thread has a couple of PDFs I posted for working on the package tray.
Old Feb 13, 2018 | 04:58 AM
JohnnyCake's Avatar
JohnnyCake
For you newbies in the forum -- there was a reason VVTiBob got a huge reception on his return!
Old Feb 13, 2018 | 08:59 AM
DshngDaryl's Avatar
DshngDaryl
Thanks for the correction Bob. I don't ever want to be the guy who gives out bad information.
I had looked up the code B2521 and it said it was "Roof Close Switch RH Malfunction." One of the causes was the "Slid Roof Limit Switch." So I googled "Lexus Slid Roof Limit Switch" and came up with part number 84742-24090. I put that into the forum search box and came up with your post.
So I assumed the problems were related, but maybe they use the same switch for two things, or the part number is wrong
Old Feb 13, 2018 | 09:23 AM
VVTiBob's Avatar
VVTiBob
Well my post’s part number ended in 240(3)0 not (9)0 (package tray switch) as you mentioned. What’s more important is to order the correct part for the VIN of your car. VIN manufacturering dates can make a difference with changes to part lots or revisions.
But the clue in this case was “roof close” which happens at the A pillar. But you’re also right the switches, at both positions, probable “do” the same function sending data to the roof ECU. I’ve also found the search function at Club Lexus tend to be very general with responses especially with partial matches. So it’s best to read the info thoroughly.
