Climate control problem
Old Dec 7, 2017 | 04:38 PM
LEXZILLA's Avatar
LEXZILLA
Default Climate control problem
the problem is that I cannot change the temperature numbers on the drivers side button on my climate control
the passenger side button works fine
Old Dec 8, 2017 | 08:20 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Ebay bound
https://www.ebay.com/sch/Car-Truck-P...D1387068227498
Old Dec 12, 2017 | 08:34 AM
GmanSC's Avatar
GmanSC
Turn on DUAL?
Old Dec 12, 2017 | 11:20 AM
LEXZILLA's Avatar
LEXZILLA
I tried that ...
but the temperature numbers will not move i
have another climate control at home that works fine but the LCD is all messed up
Old Dec 12, 2017 | 11:37 AM
LEXZILLA's Avatar
LEXZILLA
Can I change the circuit board behind the LCD screen?
Old Dec 12, 2017 | 12:05 PM
DshngDaryl's Avatar
DshngDaryl
I would guess so. It looks like if you disconnected all the wire harnesses and unscrewed the little black screws, it just kind of snaps in place.
I have never tried it myself, so I can't tell you for sure, but I think it would be worth a shot.
I am sure there are more screws than I could see in your picture, so make sure you get them all undone.
Old Dec 12, 2017 | 03:14 PM
LEXZILLA's Avatar
LEXZILLA
I'm just wondering if the lcd is connected to that circuit board?
sending out a call to ANYONE who would know that please
thanks in advance
Old Dec 13, 2017 | 07:47 PM
LEXZILLA's Avatar
LEXZILLA
Anyone????? Please help it's cold here
Old Dec 14, 2017 | 06:19 AM
Coleroad's Avatar
Coleroad
Try to PM Retroplay. If anyone on here knows he does. I know he isn't on much, but maybe if he sees a PM in his email he'll respond.
Old Dec 14, 2017 | 04:58 PM
LEXZILLA's Avatar
LEXZILLA
I sent a message to retroplay I hope he replies if anyone know please let me know
thanks
Old Dec 14, 2017 | 07:55 PM
Retroplay's Avatar
Retroplay
The LCD is soldered to that board, yes. And you cannot remove the board without removing the LCD (and it is a pain in the butt!). If you want to attempt it, cut a long piece of solid copper wire (18-20ga would be perfect) as long as the row of pins. Set this wire along the row of pins and solder it to the last pin on either end of the row. Then use a high wattage iron to heat the entire copper strip until it melts the solder on all pins at once so you can pull the LCD off.
I assume that you are thinking that button is bad? Neither up nor down works at all (or is it already moved to one extreme and you can't move it the other way?) The rocker is actually two buttons so if they are both non-functional, it is probably unlikely to be just bad buttons.
If it is just the buttons, then most likely the carbon on the back side of that rubber pad has worn out. You can buy a conductive ink pen and reapply carbon to the bottom of the rubber. You might even get away with just using a graphite artists pencil. You can lift that rubber sheet without having to take off the LCD, too. While you are in there, take a hard eraser to the contacts on the board as well.
Carbon Conductive Ink Pen
https://www.amazon.com/MG-Chemicals-Carbon-Conductive-Pen/dp/B01LZX06PL/ref=pd_sim_328_3?_encoding=UTF8&psc=1&refRID=WECE8Y2H9S2ERMZS7C24 https://www.amazon.com/MG-Chemicals-Carbon-Conductive-Pen/dp/B01LZX06PL/ref=pd_sim_328_3?_encoding=UTF8&psc=1&refRID=WECE8Y2H9S2ERMZS7C24
I would recommend giving that a try first since it is very easy to do. I would do this on the DUAL button as well just in case.
If that doesn't fix it, you have some bigger things going on. The signals from the buttons go through those flex cables. The actual microcontroller and temperature controller are on the board that fits in the tray.
My point is that you shouldn't have to mess with the board the LCD is attached to. It *could be* that, but it is the least likely cause.
Old Dec 14, 2017 | 07:57 PM
Retroplay's Avatar
Retroplay
If you get stuck, I would be willing to fix it for you. I am unfortunately not the fastest right now after moving and the new job (working almost 20 hours of overtime a week right now) which is why you guys haven't seen me around much in a while.
zes
19
Apr 26, 2017 10:57 AM
sc3757
Dec 19, 2008 04:24 PM
Toptier
May 23, 2007 04:27 PM
looknow12
Maintenance
18
Dec 14, 2002 03:09 PM
