Passenger side inside switch not operational
Old Sep 5, 2017 | 07:34 AM
mandyfig's Avatar
mandyfig
Default Passenger side inside switch not operational
Pass side Door switch (lock and unlock), not operational from passenger side, I can unlock and lock from Driver’s side. What’s the typical root cause of this situation?
Pass side door lock-unlock switch malfunction?
Nothing has changed, suddenly about 2 months ago, it quit working. Of course the wife is upset.
Me too, getting shouted at is not good.
Old Sep 5, 2017 | 08:25 AM
mandyfig's Avatar
mandyfig
Maybe contacts on switch passenger side need cleaning and greasing? I can open and close the Pass door using the DR-Master switch.
Old Sep 5, 2017 | 09:24 AM
Helogadget's Avatar
Helogadget
Not insulting your intelligence but have you made sure the lockout button on the drivers door isn't depressed?
Old Sep 5, 2017 | 10:02 AM
GmanSC's Avatar
GmanSC
Or it's bad.
Old Sep 5, 2017 | 10:25 AM
Coleroad's Avatar
Coleroad
I've seen many times the wire connector just came loose at the door switch. I'm not sure how it happens because they have clips to hold it, but I've seen it many times.
Old Sep 5, 2017 | 10:10 PM
ShawnOk's Avatar
ShawnOk
Does it not open from the exterior handle or the interior handle or both? Could be a bad lock motor/servo? There was a post on it somewhere on the SC430 forum. Someone replaced the small motor in the door that controls the unlock/lock function and did a killer DIY. Those motors go bad often. Common issue esp with high heat areas, from what I'm told.
Old Sep 6, 2017 | 04:10 AM
mandyfig's Avatar
mandyfig
1st thing when I get home is to check the lock out button.
Old Sep 6, 2017 | 04:13 AM
mandyfig's Avatar
mandyfig
yes it opens from the outside handle, when it is unlocked. The PASS SW does not activate.
Maybe time to tear it down, yes it could be that the connector got loose, I hope so. It just happened recently. When the wife wants to get off the car and she can't, she gives me the look.
Also my remote unlock does not unlock the PASS side. It could be the loose connector. It has a 3 way connection, the local wire (pass) is not actuating.
Old Sep 6, 2017 | 07:29 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
i thought you had techstream...if so, run the troubleshooting steps to figure out the problem.
Old Sep 6, 2017 | 09:05 AM
mandyfig's Avatar
mandyfig
Thanks for reminding me. I will plug in the Techstream, will it catch it?
Old Sep 6, 2017 | 09:16 AM
Coleroad's Avatar
Coleroad
Knowing that the actuator works from the master switch. The only possible problems are wire or passengers door switch. Either way to know for sure the switch and plug will have to be accessed to test them. Visually you'll know if the plug came loose. Multimeter will test the wires and power. Multimeter will test the switch. Plus to fix any of it you'll have to open it up. In this case for me , it's bite the bullet and open it up. Time saver in the long run.
Old Sep 6, 2017 | 12:05 PM
mandyfig's Avatar
mandyfig
Yes time for surgery. It has been a while since I have put the door down. Last job done was the replacement of the speaker (ML 6x9 to Polk 6's) and repair of the tweeter (blue seal repair).
Old Sep 6, 2017 | 12:43 PM
Bgw70's Avatar
Bgw70
Veteran: Air Force
are you going to rebuild the actuator while you have the door apart?
Old Sep 6, 2017 | 01:13 PM
mandyfig's Avatar
mandyfig
I am hoping that I find a loose connection on the 3 way switch of the passenger side and that’s all the repair I will do. The actuator works. I remember reading this kind of finding and repair, just can not pin it down.
Old Sep 6, 2017 | 02:49 PM
TXFM's Avatar
TXFM
Here is the Link - Harold57 did a great job along with others:
https://www.clublexus.com/forums/sc4...removal-2.html
