Paint Correction
I did a little research on sealants and see that Opti-Coat has what looks to be a very good hand applied clear coat. Applying appears the easiest part, the many hours of clay/clean/ and other prep steps are the time and back breakers!
I'm curious to hear what experience others have had with professional detailing, pricing, and DIYs.
Thanks all.
If you dont have the tools the initial investment is quite high. Just thinking out aloud, you will need at least a random orbital polisher, various pads and pad sizes, clay bar, compounds and polishes and wax.
You can pay for the paint correction once, then wash your car with two bucket method to minimise introducing more new swirls and scratches. Use a good wax every couple of months. Meguiars had some excellent products and its easy to get and quite affordable especially where you are in the US.
I'm looking forward to seeing the final results.
I would recommend against doing the Opti-Coat as a first time DIY unless you know what you are doing. Once Opti-coat has harden its a real pain to remove without heavy cutting compound. Hi and low points can be seen in the paint if done incorrectly or water spotting if the car was driven in the rain within 24 hours of applying the sealer.
The prep work on all surfaces is the most important step. The paint needs to be flawless to do an opti-coat job else you will be sealing in the imperfections!.
I would pay the professionals who does opti-coat application all day long, at least they will apply it correctly and warrant the work.
