Rear Quarter Window Mod??
Old Feb 25, 2015 | 07:58 AM
Habious's Avatar
Habious
Originally Posted by SlvBullet
I just received the ScyTec WR84 with a temperature ventilation feature. The install page cites model WR-16. I haven't decided where I want to put the switch nor selected yet the actual switch. I am thinking of installing in the rear seat area as you mention but leave the module and fuse in the trunk area near the NavTool which I am working on right now.
Any tips for the switch?
The install page show two wire for the switch - one for up and one for down. Both want a negative signal which I guess is simply ground?
Once I see the NavTool and cameras working I'll attempt this DIY too.
Simplest thing is a SPDT momentary (center off) switch.
So, the switch would rock in one direction (to lower the windows) until you release it, and ditto for the other direction.
Having it integrated into the LuxLink makes the most elegant solution (3 short presses of the window down button activates the windows - and it's smart enough to know which direction to go).
Old Feb 26, 2015 | 08:15 AM
SlvBullet's Avatar
SlvBullet
Thanks much. Just ordered one.
Old Mar 5, 2015 | 07:47 AM
416tt's Avatar
416tt
Its one of the best mods and really worth it. Looks super cool specially with the design of the SC.
best way to start is to gather the items on list (pg 5) start looking at pics and building it, doesn't take long.
https://www.clublexus.com/forums/sc-...rt-deux-5.html
once again thanks to the creators, and those who helped me
Old Apr 8, 2015 | 10:59 PM
Black31385's Avatar
Black31385
In this one, are they are using relays instead of the switch? I want to attempt this mod because the other day I was messing around and rolled down the rear windows and it looks amazing. When I started driving it started beeping.
Old Apr 11, 2015 | 08:39 AM
Black31385's Avatar
Black31385
Is this the correct switch?
http://www.ebay.com/itm/Rocker-Switch-SPDT-On-Off-On-16A-125VAC-/181677131439?pt=LH_DefaultDomain_0&hash=item2a4ccd06af
Old Apr 11, 2015 | 11:57 AM
WIL44's Avatar
WIL44
Originally Posted by Black31385
Hi Black
No you need a momentary on-off-on switch. The one in your post is not momentary,
This one is.
http://www.ebay.com/itm/Momentary-on-off-on-SPDT-12V-24V-110V-UP-DOWN-WINDOW-CONTROL-SWITCH-11CR-/291279852142?pt=LH_DefaultDomain_0&hash=item43d1a1d26e
Cheers
Steve
Old Apr 11, 2015 | 08:22 PM
Black31385's Avatar
Black31385
Thanks I was about to order the wrong one
Old Apr 12, 2015 | 06:05 PM
ShawnOk's Avatar
ShawnOk
Hey Black, I sent you a PM earlier. Check it out and let me know what you think.
Old Jun 12, 2015 | 02:37 AM
Lexb4sex's Avatar
Lexb4sex
Hello guys and gals. I have recently purchased a SC430 and loved this mod. I was messing around and loved the way the car looks with this rear window down. I have been searching ways to attempt this mod but am very scared to do it. I have just purchased the window roll up/down module but it seems there is only information with the install on with the relays. Has anyone else attempted this mod with the window roll up module?
Old Jun 14, 2015 | 11:26 PM
Lexb4sex's Avatar
Lexb4sex
Default Wiring
Alright, I am having some issues. I am not very good at this and wanted to run this by you guys before attempting to try this. What I got so far is blue and green wire to switch......brown and white wire to switch.......red to power........black to ground.........white/ blue and blue/black to left motor.......green/black and brown/blue to right motor.......and the yellow wires are not needed?
Can anyone confirm if this is right?
Old Jun 14, 2015 | 11:28 PM
Lexb4sex's Avatar
Lexb4sex
Default Another pic
Here is the picture of the instructions
Old Jun 15, 2015 | 03:40 PM
Lexb4sex's Avatar
Lexb4sex
can anyone confirm if this is the way to wire it?
Old Jun 15, 2015 | 04:03 PM
JohnnyCake's Avatar
JohnnyCake
Lex B4 Sex? Clearly, I'm just a prude.
Old Jun 15, 2015 | 04:17 PM
NickTee's Avatar
NickTee
What to you expect from someone that uses "B4" rather than "before."
Old Jul 21, 2016 | 02:11 PM
ShawnOk's Avatar
ShawnOk
Hey all, going to attempt this mod soon enough with some help. Does anyone have a full complied DIY, start to finish?
