random cold start rpm question.
Old Oct 2, 2012 | 04:12 PM
Tensi's Avatar
Tensi
Default random cold start rpm question.
In my other cars, when the cars are cold the rpm's start a little higher, and after probably 20 seconds or so.. it drops down... goes from about 1200 to maybe 700. I noticed in my SC, that there is virtually no change. It starts at its normal operating temp. Just curious why that is. Any input would be awesome.
Thanks!
Old Oct 2, 2012 | 06:21 PM
mrblister's Avatar
mrblister
Mine starts at higher speed and then lowers as the car warms up. It may have to with the actual temp. The old cars had chokes the newer cars I think are programed via the ECU as well as the maf air sensor.
Old Oct 2, 2012 | 06:26 PM
Tensi's Avatar
Tensi
Hmm, weird. I mean, when i drive I can feel the car isn't warmed up.. obviously. But the cold start, rpm starts where it would be when warm as well.
Old Oct 2, 2012 | 06:41 PM
mrblister's Avatar
mrblister
Mine is a 2005 like yours. When it starts it runs faster and then will settle down after a while. Its allways been that way.
Old Oct 2, 2012 | 08:10 PM
Tensi's Avatar
Tensi
Runs faster, you mean the RPM is running higher right?
Old Oct 2, 2012 | 08:19 PM
mrblister's Avatar
mrblister
yes higher RPM
Old Oct 2, 2012 | 08:41 PM
Tensi's Avatar
Tensi
So strange. Mine definitely doesn't. Now I am gonna measure it in millimeters. haha
Thanks for letting me know what your SC is doing though.
Old Oct 2, 2012 | 11:32 PM
Scarletti's Avatar
Scarletti
Mine starts at circa 1500 and drops down to 700 after warmed up. You'll notice it depends if your in Park or Drive though, clearly the ECU is making assumptions and trying to get it warmed up.
Old Oct 3, 2012 | 08:18 AM
kjcole's Avatar
kjcole
Coolant temperature and vacuum is sensed and ECU is programmed to inject more fuel/less air (richer) when the data map onto a 'cold start'. Failure to start with higher RPMs under true cold start (cold ambient temps, cold coolant) could reflect a coolant temp sensor that is failing, or a slight vacuum leak (for example, at the PCV piping, etc), among other things.
Old Oct 3, 2012 | 11:10 AM
Tensi's Avatar
Tensi
Oh no! Thanks kjcole... damn it.
Old Oct 4, 2012 | 04:42 AM
8Mile's Avatar
8Mile
Hi
A picture says more than a thousand words, my SC 2007
Cold engine in Park mode
Cold engine in Drive mode
Warm engine in Park mode
Warm engine in Drive mode
// Staffan
Old Oct 4, 2012 | 08:43 AM
Tensi's Avatar
Tensi
8Mile, I love you and appreciate that so much. I am going to check at every interval like you did for me, and report back.
I was thinking that in cold/park that it would eventually drop. But I guess I need to move and such. Will check!
Thanks again 8Mile!
Old Oct 9, 2012 | 05:44 AM
8Mile's Avatar
8Mile
Tensi nice to be able to straighten your question mark.
It takes about 5 minutes before it has normal idling speed (my Sc).
// Staffan
Gmach
Jan 10, 2016 05:58 PM
RCM83
IS F (2008-2014)
Dec 2, 2013 03:44 AM
MRKilroy
Aug 11, 2009 01:00 PM
runningox
Jan 12, 2009 03:40 PM
PsiQo1
Dec 1, 2006 12:10 PM
