Weatther Stripping/Gasket Replacement Question
Old 09-29-11, 08:48 PM
rennwerkes
rennwerkes's Avatar
Default Weatther Stripping/Gasket Replacement Question
Has anyone replaced the rubber gaskets/weatherstripping that run the width of the car near top the windshield and the rear window? This is what seals the convertible top when closed.
Mine are looking worn out and wanted to replace them.
Hoping it's a simple R&R.
Old 09-30-11, 06:24 AM
scyul
scyul's Avatar
This thread might help...
https://www.clublexus.com/forums/sc-...nk-screen.html
Old 09-30-11, 12:28 PM
rennwerkes
rennwerkes's Avatar
Originally Posted by scyul
Thanks for the link.
The parts list clearly show the gaskets that I was referring to.
However, seems as though the original poster, like me, was wondering about the install of the gasket and no one chimed back in about that.
Old 09-30-11, 02:14 PM
VVTiBob
VVTiBob's Avatar
It's not difficult, just tedious with a substantial number of clips and screws that must be removed from the interior garnish pieces. BUT while you have the roof "up" to work on it, you must be careful to NOT alter/tweak the roof alignment while you're working on it. Then adding new butyl to the new weather strip to seal it properly.
Unless they (the weather seals) are really bad, I'd try some A-303 first... http://www.303products.com/shop303/i...r-vehicles.cfm to see if you can revive them.
Attached Thumbnails Weatther Stripping/Gasket Replacement Question-weatbutyl.png
File Type: pdf
Last edited by VVTiBob; 09-30-11 at 02:32 PM. Reason: Added PDF of rear window components
Old 09-30-11, 05:18 PM
rennwerkes
rennwerkes's Avatar
Nothing is leaking but the rubber is looking a little ratty so was thinking it'd be nice to change it out.
But maybe it's better to just treat with a good shot of 303 and leave things be.
hoffy5
04-09-18 12:41 PM
danh63
RC - 1st Gen (2015-present)
03-27-15 12:26 PM
Tom57
02-05-15 05:38 PM
Track5tar
SC- 1st Gen (1992-2000)
10-27-10 05:34 PM
mason2006
08-09-07 11:40 AM
Quick Reply: Weatther Stripping/Gasket Replacement Question
