Camshaft Seal Replacement
Old Feb 3, 2015 | 01:08 PM
Tom57's Avatar
Tom57
Default Camshaft Seal Replacement
With 254K on the clock of the '01, I'm seeing a little oil weep after the car has been parked. I replaced the valve cover gaskets about a year ago. The cam and crank seals are original. I'm assuming a cam seal is leaking, though I haven't isolated that yet. I'm considering DIY replacement if that is the source of the oil leak. There are CL threads on TB/WP replacement, but I found no thread showing the steps to replace the 3UZ-FE cam and crank seals. Obviously, all of the steps for the TB/WP replacement are necessary to do the seals, but what are the additional steps required to complete the cam seals replacement? I know the cams must be removed. Do the valve covers have to come off and the cam journals removed as well or can the cams be carefully extracted and re-inserted from the front of the 3UZ-FE? Should the cam bearings be replaced too? This is not your average DIY I know and don't expect many to have done this. Thanks in advance.
Old Feb 3, 2015 | 02:22 PM
KA8's Avatar
KA8
It's a big job. You need to get to cam shaft. Might as well do wp/tb, crank seal, vvti gear seals etc
Old Feb 3, 2015 | 04:18 PM
ancdmd's Avatar
ancdmd
My slow oil leak turned out to be BOTH camshaft timing tubes. $2400 repair, included $700 for those two parts alone. Valve covers had to come off, and while they were in there they did the cam seals, spark plug seals/tubes, timing belt and front crank seal. Have fun!
Old Feb 3, 2015 | 07:18 PM
BradTank's Avatar
BradTank
I'd just let it leak, assuming we're talking about something small.
Old Feb 4, 2015 | 10:59 AM
Tom57's Avatar
Tom57
Originally Posted by rkw77080
No sure how much these will help... Please let me know if you need anything more specific.
Thank you, as always, rkw. If there is anything step-by-step sequence and torque info?
Old Feb 5, 2015 | 05:38 PM
randal's Avatar
randal
Tom, I believe the 98 LS400 with VVT might be close to your engine. Not exact but many similarities. In 98, the engine was changed in many ways and the cams must come out to replace the cam seals. The following post concerns a 98 LS400 where you may glean some useful info -> http://us.lexusownersclub.com/forums...i/#entry473194
Giorgio13
Apr 27, 2019 09:49 AM
pooby
Apr 29, 2017 10:34 AM
Pogigreg
Jan 28, 2012 11:50 PM
vtec-this
GS - 1st Gen (1993-1997)
Mar 10, 2008 12:27 PM
