Replacement Key Compatibility?
Old Dec 25, 2010 | 09:05 PM
Fashion's Avatar
Fashion
Default Replacement Key Compatibility?
My girlfriend lost one of the master keys for her 2003 SC430. I purchased a new blank on ebay and have a left over key from my RX330. Can the RX330 transponder be programmed for the SC? The buttons for the RX have a PWR Door text instead of car/trunk open symbol.
Old Dec 26, 2010 | 06:57 AM
mandyfig's Avatar
mandyfig
I think they all use the same transponder chip, so yes could be programmed. Regarding the power door-trunk, do not know.
Did you get thenkey cut? Where did you bring it to?
I have an SC key coming from ebay too.
Old Dec 26, 2010 | 10:01 AM
scdroptop's Avatar
scdroptop
I believe that the SC and RX transponders are not interchangeable because of the different functionalities.
I do however know that the other sedans ES, GS, LS and others at one time were with the SC because I had bought some as spares and used them myself.
Cheapest way to do it all is a 3 or 4 step process...
Buy the blank new key on eBay... $10-$15 uncut
Get the transponder separately or use old one from your SC...
(I always put a new, fresh battery in at this point...Home Depot $4.00)
Have key cut at either Lexus (quicker and easier) or search and search for local locksmith that can do it...
If you pay for Lexus $$$$ to do it, see if you can ask them to "throw in" the programming for the key cut price (I did and they hooked me up) if not, do a search on this forum on how to program the key and follow the 18 step process to do it...it's fairly easy put on your patience hat!
The cheapest you can do it for is about $55-$60 with a cheap locksmith cutting it, but a lot of people pay $100 and up if they have to have Lexus cut it, and of course depending on if they have to buy transponders or not.
Here are some good buys on eBay:
****I would use this vendor if I needed a key today...very good deal...just need the transponder now****
http://cgi.ebay.com/ebaymotors/LEXUS...Q5fAccessories
***Here is one with the transponder for $79 that just needs to be cut and programmed***
http://cgi.ebay.com/ebaymotors/2002-...Q5fAccessories
Here's a used transponder you can buy and use the guts if you don't have one for $60:
http://cgi.ebay.com/ebaymotors/2002-...item19bc09ca2e
I'm sure there are transmitters/transponders that you can buy from CL vendors like Carson Toyota and Sewell, I did a quick search and couldn't find it, but if you want to pay more than a used one for a new one, then you can go there.
Hope this helps
Old Dec 26, 2010 | 08:04 PM
mandyfig's Avatar
mandyfig
Great help. Sewell sells them at a discount for CL members.
avihi
Dec 4, 2018 05:48 PM
matts6887
RX - 1st Gen (1999-2003)
Aug 11, 2015 04:36 PM
jlkeller57
Mar 11, 2014 10:36 PM
jasone36
Sep 9, 2011 11:09 AM
heatoo
Oct 27, 2009 06:03 PM
