Check Engine Light on... CRAP!!!
Old Jul 31, 2010 | 01:50 PM
HVisone's Avatar
HVisone
Originally Posted by TEXAS83
Damn! I do this all the time. Will have to cut it out. Will take the car to my local toyota guy to see if they can fix it.
Same code my wife had...when we checked it at Autoparts store
i would buy new cap and reset the light (via battery) to see if it comes back on again...the gas can get up into the vent opening......
or spend way too much money at the shop, doing what you could have done most likely at home, and in a few hundred miles have it come back on if the gas gets back in there.
Old Aug 3, 2010 | 02:25 PM
TEXAS83's Avatar
TEXAS83
I bought the new cap today and will stick it on later. Are there any directions as to how to properly disconnect the battery? I don't want to shock the hell outta myself...
Old Aug 3, 2010 | 02:30 PM
VVTiBob's Avatar
VVTiBob
just disconnect the negative terminal. Black is neg, red is positive.
Old Aug 8, 2010 | 06:10 PM
WISLUGGO's Avatar
WISLUGGO
Man I love this site!! I just got the car back from the shop on Wednesday of this week, and my wife and I were going over the finer points of driving the SC (she is taking it to work while her car is in the shop) We take it out, and bring it home and while she is going through the gears the Check Engine lite comes on.
I tightened the gas cap, and reset the car by undoing the neagitve terminal...lo and behold, no Check Engine lite.
Old Aug 8, 2010 | 07:01 PM
Harold57's Avatar
Harold57
I wonder if resetting the ECU through the procedure posted earlier would clear that alarm also. That way you don't have to disconnect power and lose all your settings.
Old Aug 9, 2010 | 12:19 PM
coach1's Avatar
coach1
I believe the light will reset itself, given a day or so of driving, without disconnecting the battery....of course....that will do the job immediately.
Old Aug 11, 2010 | 09:59 AM
TEXAS83's Avatar
TEXAS83
UPDATE: I bought the new gas cap, unplugged the negative terminal for 2 minutes, and BAM! Check engine light went away just like ya'll said! Amazing, thanks for the help and saving me a trip to the dealer!!!
Old Aug 11, 2010 | 10:24 AM
VVTiBob's Avatar
VVTiBob
If get a chance, stop by one of the chain autoparts store and see if they'll scan the car for you to see if it stored any trouble codes.
Old Aug 11, 2010 | 10:32 AM
TEXAS83's Avatar
TEXAS83
Yea I'll go by Autozone sometime soon to do that.
Old Aug 12, 2010 | 10:47 AM
ausbun's Avatar
ausbun
Default Similar problem on RX 300
I had a similar problem on my wife's Rx 300, and my garage man said the issue could be one of several sensors and the only way to find which one is to start replacing them one at a time until the light went out. I didn't do anything and the light went out on my next long trip.
Old Aug 12, 2010 | 06:52 PM
WISLUGGO's Avatar
WISLUGGO
Well after resetting the CPU my check engine light came back on...so it is off to autozone.
Old Jun 15, 2013 | 10:41 AM
kenaroo's Avatar
kenaroo
Default Old thread but it helped solve my code issue
Old thread but thanks for posting
My check engine light was a result of a loose hose connection as pictured by talwang
Thanks
Old Jun 15, 2013 | 11:49 AM
V300Graham's Avatar
V300Graham
Thanks
Kenaroo, that tube comes loose when you have a torn engine mount. The engine moves too much and the pipe pulls off. It's time to check the mounts now I think.
Old Feb 24, 2015 | 01:55 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Thanks
I have the same issue...the hose was loose.
Old Feb 24, 2015 | 01:56 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
Looks like I may need to change the motor mounts.
