Antenna mast replacement
Old Aug 4, 2010 | 05:58 PM
KaiserSea1's Avatar
KaiserSea1
To loosen the nut I put a flat head screw driver and tapped it with a hammer counterclockwise, very easy to remove. As far as aftermarket quality here is an indication. I installed a simple tech aftermarket iPod adapter which hooks up to th antenna jack behind the head unit and is rf modulated. The unit is powered to block out any radio transmissions. With the oem mast the station still got through. I just replaced the mast yesterday with one from antennamastsrus 13$ off ebay. It works fine but does not grab a signal strong enough to interfere with my iPod adapter. For once I am happy a product is inferior to oem.
Old Aug 7, 2010 | 12:38 PM
1NEAT_SC's Avatar
1NEAT_SC
Does anyone have the information/instructions to gain access to the SC430 antenna motor? The plastic has broken off inside the motor so I'll have to get to it to see if I can remove it. Thought I would read up on it before I dived in.. (-:
I've done a "Search", but was unable to come up with the instructions. I've read them before so I know they're there, but I was unable to find.
Thanks,
Lar
Old Aug 7, 2010 | 01:01 PM
VVTiBob's Avatar
VVTiBob
Here ya go... Be careful removing the gray plastic garnish clip, they break easily and lexus wants way to much money for a few pennies of plastic.
File Type: pdf
Old Aug 7, 2010 | 01:11 PM
1NEAT_SC's Avatar
1NEAT_SC
Thanks Bob, I think I can work with that. Tomorrow's project....
lar
Old Aug 7, 2010 | 02:38 PM
VVTiBob's Avatar
VVTiBob
If you need the entire trunk overhaul let me know. It covers the whole inside and all mechanisms.
Old Aug 7, 2010 | 03:26 PM
1NEAT_SC's Avatar
1NEAT_SC
10-4 Bob, thanks. If I need it, I certainly give you a yell.
lar
Old Aug 8, 2010 | 04:03 PM
1NEAT_SC's Avatar
1NEAT_SC
Default Broken nylon worm
Sure enough that's what it was. The nylon worm that works the antenna up and down was broke inside the motor. Opened the motor and removed the nylon worm and checked for reason for it breaking and reasembled. Total time about 3.5 hours. Not complicated at all. Just time and patience. All good now.
lar
Attached Thumbnails Antenna mast replacement-p1010019.jpg   Antenna mast replacement-p1010018.jpg   Antenna mast replacement-p1010017.jpg   Antenna mast replacement-p1010022.jpg
Old Aug 8, 2010 | 04:31 PM
VVTiBob's Avatar
VVTiBob
Congrats and great photos too.
Old Aug 8, 2010 | 04:40 PM
1NEAT_SC's Avatar
1NEAT_SC
Thanks, meant to throw a big thanks for the instructions to you...so Thanks. Helped a lot. Damn.....sure have to remove a lot of stuff.. It was almost fun..(:
lar
Old Aug 8, 2010 | 06:05 PM
VVTiBob's Avatar
VVTiBob
Almost fun? Really? About as fun as hitting your thumb with a hammer I bet. Nevertheless, great work. Glad to help.
Old Sep 11, 2010 | 11:00 AM
drlazor's Avatar
drlazor
Default thanks
Thnaks for the photos. One tip is I used needle nose pilers to remove the screw on the antenna master.
GamblerZ
Feb 7, 2018 11:06 PM
SrWilliams
Jun 7, 2016 07:34 AM
igorxx
Jan 24, 2012 08:50 PM
avalon42
Nov 19, 2011 05:31 PM
Petrie2001
RX - 1st Gen (1999-2003)
Mar 31, 2006 06:26 AM
