Ignition Key Won't Turn
Old Mar 28, 2010 | 05:37 PM
shivett's Avatar
shivett
Question Ignition Key Won't Turn
My daughter and I both have 2003 SC-430's. Occasionaly when we try to turn the key it will not turn. The steering wheel must be jerked violently to "unlock" and then it will start. It has to be jerked in the direction that would straighten the wheels. Sometimes this takes several minutes. My mechanic said to always park with the wheels straight ahead, however it still happens even if they are just slightly turned. This happens in both cars so assume it is a common problem. Any comments?
Old Mar 28, 2010 | 06:17 PM
JohnnyCake's Avatar
JohnnyCake
I have not had this problem with the SC, but with other makes, it is often necessary to take any torque off the wheel before the key will turn.
Old Mar 28, 2010 | 08:20 PM
deadeyed's Avatar
deadeyed
Most car do, just a security feature. The steering will be locked if you turn it w/o the key inserted.
Old Mar 28, 2010 | 10:02 PM
CAMAracer's Avatar
CAMAracer
Yeah, this is a security feature called steering-wheel lock. To avoid this from happening, try not to use the steering wheel as a support while getting out of the car.
Old Mar 29, 2010 | 04:06 AM
Turboo's Avatar
Turboo
This is exactly what I was going to say. Usually we tend to use the steering wheel as a support and then it locks. so when we come back and try to turn the key it wont unless we turn the steering.
To avoid that I do the following:-
1- When I park my car and before shifting the gear to P, I first put my steering wheel straight. Then I press the leg break fully then I move the gear to park.
2- When I get out of the car I turn fully toward the door, push myself outside and but my feet on the ground. Then I stand up with my hands one on the door and the other one on the seat.
Hope this help
Old Mar 29, 2010 | 05:06 AM
deadeyed's Avatar
deadeyed
or get out of the car before you pull the key
Old Mar 29, 2010 | 06:24 AM
tfischer's Avatar
tfischer
25 Year Member
There should be no need to "jerk" the steering wheel "violently." The torque in the system is simply putting pressure on the key locking mechanism, and happens in all cars. It's usually mentioned in the manuals. Turning the wheel while applying pressure on the key will let you know when the pressure is released, allowing the key to turn.
Old Mar 29, 2010 | 07:46 AM
shivett's Avatar
shivett
Default Ignition Key Won't Turn
Hope this help
Thanks to everyone who answered. I just wanted to know if this is a common problem with the SC-430. Obviously it is. I will try to remember your good advice.
Shivett
Old Mar 29, 2010 | 07:51 AM
tfischer's Avatar
tfischer
25 Year Member
It's a common problem with almost all cars made in the last 20 years. It's clearly inherent in the mechanics used, as an electric or electronic mechanism is surely not going to work for this situation.
Old Mar 29, 2010 | 08:59 AM
Solman's Avatar
Solman
I disagree that it is a common problem to the SC. It happened to me once or twice in two years. That is about the same average with my other two cars.
Old Mar 29, 2010 | 09:06 AM
deadeyed's Avatar
deadeyed
Shivett
it's a feature, not a bug.
Old Mar 29, 2010 | 09:09 AM
tfischer's Avatar
tfischer
25 Year Member
By common, I meant that it happens with all cars, but seldom.
I consider it a minor annoyance not mention-worthy.
oldcrowe
Jul 3, 2015 09:24 PM
YupImJOee
GS - 1st Gen (1993-1997)
Apr 14, 2010 08:24 PM
jerrygrier
Dec 4, 2005 08:27 AM
Grumpy
Mar 23, 2005 08:11 PM
3dog
Dec 2, 2003 02:16 AM
