Quote:
thats wat i was looking for thanks talwag!Originally Posted by talwang
194 is the bulb number, you can use 168 as well.
BTW.. I went to put them on and the left bulb was fine.. but wen i put the bulb on the right.. it kept blowing the fuse out.. so i hope its just a bad bulb
You most likely have a short in your wiring then. A "bad" lamp opens the circuit, drawing no current, and the fuse does not blow.Originally Posted by Rahstyles
thats wat i was looking for thanks talwag!BTW.. I went to put them on and the left bulb was fine.. but wen i put the bulb on the right.. it kept blowing the fuse out.. so i hope its just a bad bulb
Quote:
But the oem ones both work..Originally Posted by PHXSC
Quote:
Cause i want the hyper white led's Originally Posted by PHXSC
then why are you replacing them?
Instead of the orangy color
