Orange on rear light
Old Oct 27, 2008 | 08:53 AM
evolution8's Avatar
evolution8
Default Orange on rear light
Do you know where I can purchase a rear vinyl to cover the orange signal on the rear tail light? This is a mod that was popular on RSX forums.
Old Oct 27, 2008 | 10:24 AM
aquanuke's Avatar
aquanuke
Do you mean the orange of the bulb? If so just buy those chrome bulbs that that flash orange.
If you mean tint for the older type rear lense then ebay used to sell it precut for a few dollars.
Old Oct 27, 2008 | 02:17 PM
evolution8's Avatar
evolution8
The red vinyl, a red-out.
I couldn't find any on ebay but thanks. I guess I will just buy some red vinyl and cut it to match.
Old Oct 27, 2008 | 02:36 PM
aquanuke's Avatar
aquanuke
Oh right no not red, only seen smoke.
http://cgi.ebay.com/ebaymotors/LEXUS...mZ350110242321
Old Oct 27, 2008 | 02:38 PM
aquanuke's Avatar
aquanuke
Oh right no not red, only seen smoke. Although might be worth asking them to cut you a red one.
Old Oct 27, 2008 | 06:11 PM
Lexiss_sc430's Avatar
Lexiss_sc430
I just bought a sheet and did it myself,
https://www.clublexus.com/forums/sho...light=pictures
Old Oct 29, 2008 | 02:46 PM
evolution8's Avatar
evolution8
http://www.decalfx.com/pre_cut_lens_film_kits.html
Finally found it here. $40+ for red rears.
Old Oct 30, 2008 | 08:53 AM
tsc430's Avatar
tsc430
tommy, how hard was it to cut the sheets yourself? any tips? thanks
Old Oct 30, 2008 | 12:54 PM
Lexiss_sc430
It’s really easy, and honestly I'd recommend getting the sheets, you have to be 100% precise with the pre cut pieces or else you will mess it up, with the sheets if you mess up you can try again with another piece. What I did was cut a piece a few inches bigger on each side, then I applied it onto the light, I used a blow-dryer to make things a little easier. Then just take a sharp knife, razor (preferred cutting tool) and run it along the grove created by the light and the body panel, work perfectly and never had any issues with the film peeling or fading. Oh yea and it's cheaper too!
Old Oct 30, 2008 | 05:03 PM
evolution8's Avatar
evolution8
Where do you buy the sheets, from those sites?
DecalFX won't ship to Canada. h:
Old Oct 30, 2008 | 06:08 PM
Lexiss_sc430
http://www.rvinyl.com/wrapkits/vinyl...taillights.htm
and I think they will ship to Canada.
Old Oct 30, 2008 | 06:23 PM
evolution8's Avatar
evolution8
Thanks, just ordered from them. I was hesitant before because they said 14-21 days but better than nothing.
Old Oct 30, 2008 | 06:33 PM
Lexiss_sc430
Once the kit arrives you will see that they included a plastic applicator.
Clean the surface of the lights, use the corner of your towel or q-tips to get the crack between the body panel and the light, you want to make sure all surface dirt and grime it removed.
Once you are sure the surface and all cracks are clean, get a 2nd pair of hands to help you. follow the instructions I posted above and you should be ok, have one person tug on the vinyl and hold the blow-dryer 6-9 inches off the material and just work the material on the light with out over stretching it or allowing wrinkles to settle. Once cut use the applicator wedge in the ends/corners of the material into that crack you earlier cleaned. Use the blow-dryer and make sure that material sticks in those areas. I didn’t even bother doing the little top piece it all looked the same afterwards
Old Oct 31, 2008 | 11:52 AM
evolution8's Avatar
evolution8
OK thanks again.
I ordered the small sheet, that's big enough?
Old Oct 31, 2008 | 02:13 PM
Lexiss_sc430
umm I cant remember off the top of my head but just measure the light and x2
jtszwed
Feb 23, 2015 01:49 PM
Jaked
Feb 17, 2014 10:10 AM
jasone36
Apr 10, 2012 10:37 PM
giveitall
Dec 22, 2009 01:44 AM
peterAP2
Jun 17, 2007 12:43 AM
