Window Problem
Old Apr 17, 2008 | 10:33 AM
exesc430's Avatar
exesc430
Default Window Problem
My automatic windows seem to be disabled on my SC. Does anyone know how to enable this function?
Old Apr 17, 2008 | 10:50 AM
Lexiss_sc430's Avatar
Lexiss_sc430
Make sure you have not pushed the window lock button.
Have you checked the fuse?
Old Apr 18, 2008 | 11:57 AM
exesc430's Avatar
exesc430
Fuses checked, window button clear. Might be electrical. Let me know if anybody has any ideas. I've heard with hondas and acuras you can disable and enable the automatic window up/down feature by opening the driver door and rolling the window up then down but I was wondering if anyone knew how to do it to a Lexus or Toyota.
Old Apr 18, 2008 | 05:31 PM
Roofless's Avatar
Roofless
CL Folding 500,000
Assume you're saying the one-touch "automatic" function isn't working , but windows work normally, otherwise.
Never heard of this or the "secret" mechanics way of disabling that function, but I guess someone could have deactivated something like that.
I was wondering if it was a C-Best setting the dealer could dial back in for you?
Old Apr 18, 2008 | 06:15 PM
nclexstech's Avatar
nclexstech
was your battery disconnected recently?
Old Apr 18, 2008 | 06:40 PM
FrayKay's Avatar
FrayKay
If its just the automatic function that isn't working, all you need to do is roll down the window about an inch, then roll it back up and hold the window switch in the UP position for 5 or 6 seconds. You have to do this for each window. If that doesn't work, roll the window ALL the way down and then roll it back up and hold the switch in the UP position for 5 or so seconds.
Old Apr 19, 2008 | 08:52 PM
Roofless's Avatar
Roofless
CL Folding 500,000
Thank you FrayKay. Interesting. Assuming the same procedure will turn OFF the automatic feature as well... yes?
Hope this solves your problem, exesc430.
Old Apr 23, 2008 | 03:50 PM
exesc430's Avatar
exesc430
Thanks for all the input guys. I'll give it a try.
Leines
RX - 1st Gen (1999-2003)
May 8, 2012 01:22 AM
elvis1955
Feb 19, 2012 10:42 PM
SPS
Mar 13, 2010 12:49 PM
talbin
Sep 30, 2007 10:29 PM
D-MAN63
Maintenance
Oct 26, 2003 06:27 PM
