Rotor sizes
Old Sep 20, 2007 | 10:19 PM
PVlexus's Avatar
PVlexus
Default Rotor sizes
With the stock wheels, what is the largest size of rotor you can put on without shaving anything?
Thanks
Old Sep 20, 2007 | 10:22 PM
rominl's Avatar
rominl
exclusive matchup
don't understand your question. if you increase rotor size, you need new calipers/brackets. and with that you need new wheels
either way, 18" diameter wheels can fit 14" rotors
Old Sep 20, 2007 | 10:38 PM
PVlexus's Avatar
PVlexus
I was thinking about what size of Vented rotors from Brembo I could get. I've read that Vented rotors don't do a whole bunch, and know that, but I was thinking for the cool factor here.
What size is the stock rotor?
thanks Rominl for your quick response.
Old Sep 20, 2007 | 11:09 PM
rominl's Avatar
rominl
exclusive matchup
vented? i believe the stock are already vented. i think you mean slotted / drilled?
if so, i suggest get direct size replacement. you don't want to touch the calipers
no idea on stock size though, maybe 12.7?
Old Sep 20, 2007 | 11:16 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Not sure if they are even that large. I believe stock front rotors are 11.65" in diameter and Supra TT are 12.6-12.7". I just placed new slotted/drilled rotors on the SC as I removed the BBK a while back. Did not measure the OEM rotors other than they are very tiny-comparable to a quarter I think. Regardless of the size your only option is to get a direct replacement as going larger will interfere with the caliper so again we are a bit confused with the question. Does Brembo actually make a drilled/slotted rotor now for this car? They didn't in the past though other companies took their blanks and drilled them selling them off as Brembo which they were not.
Old Sep 21, 2007 | 01:03 AM
rominl's Avatar
rominl
exclusive matchup
you are right, 12.7" is the supra tt i believe. stock ones are small.
Old Sep 21, 2007 | 06:19 PM
PVlexus's Avatar
PVlexus
Yes, my mistake, I mean drilled. And just to double check, the stock calipers will work with these rotors?
Thanks
Old Sep 23, 2007 | 11:02 AM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
Thanks
Yes, if they are for SC430/GS400/GS430 they will work fine with stock calipers. If they were larger rotors meant for Supra TT than it would state Supra TT. If they were for Brembo big brake kit they would be $$$$$$$$$$$$$$.
I picked up a set of 4 cross/drilled new for under $130.00. They are the cheapie off shore brand but ...they actually do work well. Have/had them in my GX, GS,etc..
melymel96
Mar 12, 2010 08:50 AM
weesped
Suspension and Brakes
Nov 17, 2007 08:24 PM
$C300
Jun 28, 2007 12:07 AM
meddle
Aug 1, 2003 06:55 PM
zz231
79
Jul 7, 2001 01:55 PM
