CD Player woes
Old Jun 26, 2007 | 06:37 PM
4titude's Avatar
4titude
Default CD Player woes
Hey, folks.
I've got an '02 Sc430. Last Thursday, I disconnected the battery for a brief period. When I reconnected, the CD player won't play. There are three discs in the changer, but the LCD display shows all six slots filled. The player won't eject discs, and if I hit the load button, the machine tells me the slots are filled. The AM/FM radio and cassette player still work.
I've read in other posts that it may be an anti-theft safeguard, in which case I wonder how to reset it w/o going to a dealer.
I have repeatedly disconnected the battery and pulled the radio fuse to try a reset, but it hasn't helped.
Other suggestions would be appreciated.
Thanks in advance,
Joe
Old Jun 26, 2007 | 09:36 PM
Pearlpower's Avatar
Pearlpower
CL Folding 25,000
CD changer is a soft spot on early models. What is describe is one of the issues that comes up.
Any error codes? Most of the time error 3 comes up.
Dealer can usually get a rebuilt for under $500.00
Ebay list a few from time to time but all of the ones I received were defective (3) and had to be returned.
Old Jun 27, 2007 | 02:04 PM
4titude's Avatar
4titude
I should have added that I get a "Error 3" message. If it's a jamming issue, why would it have occurred just by disconnecting the battery? One of you guys has to have changed a battery over the years.
Old Jun 27, 2007 | 07:32 PM
ZGone's Avatar
ZGone
Exclamation Same problem fixed
I recently got an 2002 SC430 from Florida for my wife. When we receive the car it had the exact same problem with the CD player. Error 3, looked like it had six CD's in it and wouldn't do anything. I figured that the unit was jammed and basicly trashed inside, although the radio and tape played fine. I was expecting to have to find a unit on Ebay or shell out $1500 for a new headunit. Well I had to take it in to the dealer to get the O2 sensor replaced. When I got the car back the CD player was fine and plays perfectly. When I initially pick up the car the VSC control was going off so I left the car for pickup the next day. They said that the tech didn't allow the computer system to boot completely. I would talk to your dealer about the problem you are having and see if it just needs a cpu reset.
Good luck.
Old Jul 2, 2007 | 10:23 AM
4titude's Avatar
4titude
Angry
At least life works out for one of us. This car is getting to be the costliest mistake I've made in a while. Any one know how to input the "shape the f*(k up" code into the car's computer?
Old Jul 2, 2007 | 06:07 PM
ZGone's Avatar
ZGone
Default Tsib Mark Levinson Amplifier
4titude,
One other thing you could try is allowing the amp to iniatilize the system. There was TSIB on this back when the amp in the 2002 were getting replaced. This may essentially be what the system is thinking when it totally losses power for a given length of time and is seems like the amp has a lot to do with the systems operations. Here is the procedure:
1. With the ignition key out of the ignition, install the replacement amplifier into the vehicle.
2. Insert the ignition key into the ignition, turn the ignition key to “ACC” and wait for 5 minutes.
NOTE:
During this 5 minute period, the amplifier is initializing itself to match the vehicle’s audio settings.
3. After 5 minutes, turn the ignition key to “LOCK” and wait 1 minute.
4. After 1 minute, turn the ignition key to “ACC” and push the “Power” button on the radio to confirm normal sound system operation.
Maybe this will work......
Old Jul 15, 2007 | 03:41 PM
4titude's Avatar
4titude
A swing and a miss. Thanks anyway, though.
JLogs2981
Jul 21, 2016 10:19 PM
deedais
Sep 3, 2014 11:10 AM
93ls400WD
Feb 28, 2007 06:08 PM
