Rear brake pad replacement
Old Sep 8, 2006 | 12:54 PM
ycp's Avatar
ycp
Default Rear brake pad replacement
I've done search on this subject but haven't found any good instruction. I would of have done it at the dealer but $380 for rear pad replacement with rotor surfacing is too harsh.
Does anybody done it themselves?
What pad do you recommend?
Any link or simple instruction?
I have 2002 SC430.
thanks in advance.
Patrick
Old Sep 8, 2006 | 07:01 PM
bt430's Avatar
bt430
There's a few choices out there for you. You can always go with stock pads and rotors. I put a StopTech big brake kit on the front so I chose to go with StopTech cross drilled rotors and Axxis pads on the rear. The rear brakes are not hard to do at all.
BT
Old Sep 8, 2006 | 10:38 PM
rominl's Avatar
rominl
exclusive matchup
i got the stoptech setup for the rear as well. it's pretty easy to do. there is a clip on the caliper, you take it off and then the two "studs" can come out, and then the pads are out
azipod
Oct 23, 2018 07:15 PM
Jbthompson
Nov 23, 2015 11:00 AM
Bigrahizzl
Suspension and Brakes
Jun 18, 2011 07:18 AM
btle29
GX - 1st Gen (2003-2009)
Aug 28, 2008 05:59 AM
OutlawTita
Jul 4, 2006 01:11 PM
