Control Panel
Old Jul 29, 2025 | 05:40 PM
robmelvillere's Avatar
robmelvillere
4th Gear
Default Control Panel
Hello all, terrible day. I was replacing the ratio and pulling off the control panel. Only the faceplate came off and it disconnected from the board. When I reconnected it something shorted. The clock and hazards work, but nothing else. I purchased a working replacement but still have the same results. The abs, VSC and VSC off lights are new on. I checked nearly all the smaller fuses but didn't pull any big ones as I've never pulled those. Just wondering if anyone has had a similar experience.
Old Jul 29, 2025 | 06:13 PM
DshngDaryl's Avatar
DshngDaryl
Man, that stinks. I feel for you.
My first step would be to see if all the harnesses are plugged in tight to the new controller. Each harness does a different function. The one on the right does the roof, one does the AC controls etc, etc
Do the part numbers match on the controllers? where did you get the controller?
Old Jul 29, 2025 | 06:20 PM
robmelvillere
4th Gear
Got it of eBay. Same part numbers on outside and on the board itself. Made sure it was all tight. Given the other lights that came on, I think the problem is further down the line from the controller. Called one mechanic that does Toyota/Lexus and flat out said take it to Lexus.
Old Jul 29, 2025 | 06:25 PM
DshngDaryl's Avatar
DshngDaryl
Ok, talk me through this further, since your ABS should not be effected by the controller.
What is not working?
Does the panel light up?
Does ANY of the Ac work?
Does the roof light up?
Does your car drive?
Have you read any codes?
Is it your ABS light that is on, or your Check Engine light?
If you have a check engine light, the vsc lights go on, just to attract your eye to your Check engine light
Old Jul 29, 2025 | 06:34 PM
robmelvillere
4th Gear
The panel lights up and only shows the clock, which can be changed. The hazards work but no other buttons work, not even the open or close for the navigation. The car drives fine. Windows work. As far as I can tell everything else works. No check engine light. The only lights on are abs, VSC and vsc off. I'll have to check the roof light but I'm pretty sure it's fine.
Old Jul 29, 2025 | 06:39 PM
DshngDaryl's Avatar
DshngDaryl
I meant the roof light, as in the light that is on the button when you try to lower your roof.
Do you have a scanner to read the Codes? If not drive it to a national auto parts store and they will usually read them for you. They can't read the toyota codes, but hopefully they can read your ABS codes.
Old Jul 29, 2025 | 06:43 PM
robmelvillere
4th Gear
Gotcha. No that light isn't on. I don't have a code reader so I'll have to get on that. Thanks
Old Jul 30, 2025 | 11:02 AM
DshngDaryl's Avatar
DshngDaryl
Or you can just go to the auto part store and have them read the codes for free.
I am guessing you will need a code reader that can read toyota specific codes. Those tend to be a little pricier.
This one claims to read Toyota codes, but I do not know how well it does that
Amazon Amazon
Old Jul 30, 2025 | 02:54 PM
GregMN's Avatar
GregMN
Hello all, terrible day.......I purchased a working replacement but still have the same results.
How sure are you that the replacement worked ?
Where do you live ? Someone close by may be able to help diagnose.
Jaipgaur
Mar 19, 2025 02:16 PM
ActiveUndead
Oct 18, 2024 05:03 PM
mirko61
May 11, 2023 02:57 PM
derek49
Jan 24, 2011 09:19 AM
RX350_KSA
Dec 16, 2007 09:35 AM
