AC (mis)behavior
Old May 19, 2025 | 12:01 PM
doobs's Avatar
doobs
Default AC (mis)behavior
So,
AC season is upon us in the Tidewater.
Typically, I don't use the AC all that much, but LOML and I had to make a trip up to Northern Virginia (NOVA).
This is all interstate, and we will put the top-up with the AC on for less noise from the enormous amount of traffic on I-95.
The ac cools the car quickly as usual, but yesterday I noticed that after an hour or so the air coming on the vents was barely cool at all.
Today was the same experience. After about an hour the air from the vent was the same as outdoors.
I toggled the AC off for a couple of minutes, and then toggled it back on.
At which point, the air from the vents was it's usual cold temp.
Any idea what might be the cause of this oddity?
Thanks
Old May 19, 2025 | 01:34 PM
DshngDaryl's Avatar
DshngDaryl
I think you have a leak in your system. You can go to walmart or an auto parts place and get some r-134 and top it off.
If your car wasn't the age it is, I would tell you there was a leak and you need to worry. My theory is it just leaked out over time and a one time top off will solve the problem. If you find this solution doesn't solve your problem long term, you will need to get it looked at.
Old May 19, 2025 | 02:17 PM
AVSRacing's Avatar
AVSRacing
I thought those store refill kits aren't good cuz they have sealant in them which isn't good for the AC system in the long run. So because your system is already leaking it maybe compromised and have debris in the system which causes more damage.
Old May 19, 2025 | 04:48 PM
implantgs4's Avatar
implantgs4
Get some manifold gauges and recharge your system before you destroy your compressor.
Old May 20, 2025 | 07:59 AM
NEWONE1's Avatar
NEWONE1
Check your cabin filter make sure it's not clogged...check condenser for dust, leaves, dirt...compressor clutch can cause the AC to malfunction and a leak can also lead to inconsistent AC performance.......good luck
Old May 21, 2025 | 06:11 AM
doobs's Avatar
doobs
Thanks,
The car is going up on jackstands today to install coil overs.
I'll have a lookie see at the system once that is done.
Old May 27, 2025 | 03:59 PM
tban's Avatar
tban
3rd Gear
When was the last time it was recharged?
I would try to recharge it with dye to find the actual leak.
Otherwise clean the condenser and evaporator gently via low pressure water.
Originally Posted by doobs
So,
Thanks
Old May 28, 2025 | 05:05 AM
doobs's Avatar
doobs
I don't think it's ever been recharged. I've owned it for 3 years now and it hasn't been recharged in that time.
I'll prolly do one of the recharge kits and see how it goes.
Thanks
Old May 29, 2025 | 04:45 AM
dan25man's Avatar
dan25man
Did you look at the sightglass? Theres a glass windows you can check on the drivers side in front of the radiator. If you see bubbles in there than there's air in your system. If it's clear then you're good (no leak)
id also pull the codes to see if there's anything tripping out there. I've had the low pressure sensor go out on me before. And once replaced all was good again.
Old May 29, 2025 | 05:11 AM
doobs's Avatar
doobs
I did a check when I had the Tech stream connected to do my new TPMS integration. There were no errors other than the occupant sensors.
I'll look at the sight glass.
It's be unseasonably cool here, so I really haven't been able to test it.
I am fairly certain that one or more of the under dash servos is dieing, so that will be more fun.
Cheers
Old Jun 22, 2025 | 01:45 PM
doobs's Avatar
doobs
Well,
It's well and fully hot today. Some 95F.
I was getting on a local highway and "gave it the beans" to get past a slo-poke entering the roadway.
When I lifted off a bit, there was a very pronounced clack/clack/clack noise like a solenoid that was hunting.
When I got home, I left the car running and opened the hood. The suction line was sweating all the way to the firewall.
All my experience with HVAC has taught me that if the suction line is sweating, the system is charged.
So, my guess at this point is that I've got one (or more) of the door control solenoids is dead/dying.
Cheers,
lexnxkm
NX - 2nd Gen (2022-current)
14
Aug 27, 2024 05:23 PM
tapjoy
IS 500 (2022-2025)
May 29, 2024 03:04 PM
websurfer
21
May 8, 2024 09:05 AM
Narift
Apr 12, 2023 05:48 AM
2Fast0
May 4, 2006 07:10 PM
