Speedometer Issues
Old Apr 8, 2025 | 03:59 AM
Stuckn60s's Avatar
Stuckn60s
Default Speedometer Issues
Our 2002 speedometer stopped working and the fuel range also!!! I know it isn't cables driven, like I'm used to. Can anyone tell me where the speed sensor is located? Looking for it, I saw one that says it is located on the transmission. Is that correct? Thanks for any guidance.
Old Apr 8, 2025 | 09:58 AM
DshngDaryl's Avatar
DshngDaryl
Anything else not working?
Did you check all your fuses?
I think the feed is from the ABS ECU.
Do you think it is a speedometer issue, or a bigger issue?
Old Apr 8, 2025 | 02:28 PM
Stuckn60s's Avatar
Stuckn60s
Thanks for responding.
I have not checked the fuses yet. Just the speedo and fuel range not working.
Old Apr 9, 2025 | 10:37 PM
HawaiiSC430fan's Avatar
HawaiiSC430fan
2nd gear
I recently bought an sc430. When I initially test drove it the speedometer didn't work. The owner ended up needing to replace the car computer system. It cost him $3000, but that was here in Hawaii (everything is more expensive here). Since he replaced the computer everything works perfectly like it should.
Broseph400
Nov 15, 2022 12:58 AM
dean w
Nov 22, 2019 06:00 PM
Johnny D
GS - 1st Gen (1993-1997)
Dec 25, 2013 09:40 AM
Jerpam
Aug 17, 2013 08:58 PM
EpixINC
Mar 9, 2008 07:04 AM
