Speed sensor
Old Jun 12, 2013 | 07:12 AM
Jerpam's Avatar
Jerpam
Default Speed sensor
Which senser controls speedometer and how to check?
Old Jun 12, 2013 | 07:26 AM
EEngineer's Avatar
EEngineer
VSS attached to the back of the transmission near firewall
Old Jun 12, 2013 | 04:44 PM
400ls's Avatar
400ls
its under the airbox . simple to access and replace
Old Jun 13, 2013 | 07:14 AM
Jerpam's Avatar
Jerpam
This is for ES330
Old Aug 17, 2013 | 08:58 PM
Dink's Avatar
Dink
There are Two sensors on the ES300. The VSS is by the starter and you must remove the air filter box to get at it and the other sensor is the clutch sensor which can be seen without removing anything. Both magnetic sensors are identical on the 1999 ES300. SO i assume 1999-2001 should be that same.
ayroman
12
Dec 4, 2023 03:00 PM
oldman56
May 1, 2017 03:08 PM
Sublime69
Feb 11, 2013 12:36 PM
mrchacon
Maintenance
Jun 28, 2009 01:25 PM
pabenic12
Nov 15, 2006 08:21 PM
