3UZFE replacement on 2008 SC430
Old Oct 10, 2024 | 11:32 AM
cwajciec's Avatar
cwajciec
Default 3UZFE replacement on 2008 SC430
Hi all, I just picked up a 2008 SC430 with a locked up 3UZFE. (thinking the timing belt broke). I need to swap in a replacement and inquired to a local junkyard for another 3UZFE. He says the oil pans can be different (no problem) and to check the cylinder heads. The engine is from a GS430. I thought all 3UZFE long blocks were the same. Does anyone know of differences in the cylinder heads that may make this swap difficult or not possible?
Old Oct 15, 2024 | 12:52 PM
C8LC500's Avatar
C8LC500
I've seen complete rebuilt long blocks on Summit Racing web site. Cost about 7k if I remember correctly.
Old Oct 16, 2024 | 10:36 AM
DshngDaryl's Avatar
DshngDaryl
If you check out YouTube there are several videos that highlight the difference.
I have never tackled anything as large as an engine swap, but What I would do is keep the old engine and new engine side by side and swap over the differing components. I would want to utilize the SC ecu and engine harness, so I would uses the sensors it needs.
I would assume the engines would have all the same connectors, but I could be wrong.
Old Oct 17, 2024 | 10:15 AM
jimisbell's Avatar
jimisbell
If it was me, I would go with the 2JZ and have a ball.
Old Oct 17, 2024 | 11:39 AM
DshngDaryl's Avatar
DshngDaryl
RESPECT! You are such a Car guy; all the way down into your bones!
Old Nov 8, 2024 | 03:30 AM
cwajciec's Avatar
cwajciec
Update: bought the used 4.3 3uzfe engine from an LS430 which had 90k miles. The oil pan, pickup, and upper aluminum pan needed to be swapped from the SC430, as well as the wiring harness and dipstick. The fuel rail was also swapped over because the connection to the car was different. Last, the motor mounts were swapped. Exhaust manifolds were the same.
I dropped the engine in and it started right up! Hope this helps anyone looking to do the same.
Old Nov 8, 2024 | 04:27 AM
doobs's Avatar
doobs
Thanks for coming back and providing an update.
Old Nov 10, 2024 | 08:09 AM
DshngDaryl's Avatar
DshngDaryl
That is AWESOME! Congrats. I think you are going to love your new SC!
ghbrian
Nov 9, 2023 04:01 AM
DAVEB1980
Apr 18, 2022 04:34 AM
