TAIL LIGHT bulb
Old Jan 29, 2024 | 04:18 AM
DAVEB1980's Avatar
DAVEB1980
Default TAIL LIGHT bulb
I replaced a rear tail light bulb and how do you get the dash warning light to go away? Is there a series of buttons I need to press?
Old Jan 29, 2024 | 05:45 AM
Tanker's Avatar
Tanker
Should go away just with the new bulb. If you went LED it won't be going away though.
Old Jan 29, 2024 | 05:56 AM
DAVEB1980's Avatar
DAVEB1980
I did go LED.....wow good info!!! I guess I need to head back to autozone. HAHAHAH
Old Jan 29, 2024 | 06:07 AM
Tanker's Avatar
Tanker
I left mine on. I'd rather have the better lights. They do make parts that create a load that the LED light doesn't draw and that will turn the dash light out.
Old Jan 29, 2024 | 06:14 AM
DAVEB1980's Avatar
DAVEB1980
The LEDs are better, you are right! Hmmm maybe I will just leave them as well.
What about the fog lights? Do you just pop light out from behind the bumper? I cant find any video's on how to change. I want white bulbs vs yellow.
Old Jan 29, 2024 | 04:02 PM
PWRSLVE's Avatar
PWRSLVE
The other possible option is replacing the trunk fuse box with one from a 2006+ vehicle. This definitely works when replacing the tail light housings to the newer LED versions but not sure about just LED bulbs in the old housing. The part number needs to be 82670-24093 or 82670-24094. Dealer price on the part is crazy but I was able to find one after doing my tail light housing upgrade on eBay about a year ago for less than $50. You just need to find someone parting out a 2006+ car that doesn’t realize the newer fuse box has more value. Note that most listed are the older revision.
Old Jan 29, 2024 | 05:28 PM
digitatc's Avatar
digitatc
Assuming 2002-2005 model, black tape will fix it. You'll need to open the cluster instrument and stick it there (not on the clear plastic cover) and while you are there, upgrade the white LEDs to make the whole unit brighter.
People who did the 2006+ tail light (LED) upgrade probably did this trick instead of buying the controller for the taillight.
Old Jan 30, 2024 | 03:59 AM
DAVEB1980's Avatar
DAVEB1980
Wow that is good to know and I dont think I can do that kind of work.
Old Jan 30, 2024 | 04:00 AM
DAVEB1980's Avatar
DAVEB1980
Its an 2003 model. This is something I can try...
missouriup
Jan 29, 2024 01:01 PM
mijobo
RC - 1st Gen (2015-present)
Oct 22, 2021 06:17 PM
GS400NYC
Dec 9, 2013 07:28 PM
BlackRX
RX - 1st Gen (1999-2003)
Jan 10, 2006 12:30 PM
