Help with P0440 code, experts please chime in.
Old Jan 11, 2024 | 11:16 AM
Tanker's Avatar
Tanker
Have you pulled the back seat and looked at the fuel pump location?
Old Jan 11, 2024 | 02:59 PM
rkcnb's Avatar
rkcnb
10th Gear
The back seat was never removed but the fuel tank was brought down x2. This is a pretty big job, they have to remove the exhaust and axle, I think? The fuel pump was not suspected as a problem.
Old Jan 11, 2024 | 04:20 PM
DshngDaryl's Avatar
DshngDaryl
Does anyone recall a problem where the person couldn't start their car after they filled up with gas? It was some kind of check valve that was stuck. I think it was in the engine bay.
Anyone remember what part I am talking about? I wonder if these things are related...
Old Jan 11, 2024 | 05:35 PM
rkcnb's Avatar
rkcnb
10th Gear
In this post the following is mentioned...
https://www.clublexus.com/forums/es-...ml#post7385701
Ok, ready for this? It took some effort on the part of the technicians at Lexus but the problem was that a rodent chewed through a hose located between the filler and fuel tank (I have the exact wording on the service sheet). It was a tough spot to get to so it was a pricey fix and I'm certain I way overpaid, but I needed the car right away and didn't have time to play around trying to figure it out.
FYI, regarding the code P0440, in the past some people have mentioned that after clearing the code it can takes hundreds of miles for it to come back. The reason is not because of time or miles driven, but rather the system in which the failed part is located does not kick in until the gas tank is around 1/4 full or below.
Any idea what part this person is referring to?
Old Jan 11, 2024 | 10:23 PM
SimonPete's Avatar
SimonPete
3rd Gear
I had a similar problem with Evap , yours doesn’t look like the pre lift sc430
Old Jan 11, 2024 | 10:27 PM
SimonPete's Avatar
SimonPete
3rd Gear
That second car was what ? Black is black but it’s not Sc430
Old Jan 11, 2024 | 10:29 PM
SimonPete's Avatar
SimonPete
3rd Gear
Ok sorry man it’s covered, didn’t notice, my guys had to go through all the ev cables to find the leak
Old Jan 12, 2024 | 02:48 AM
rkcnb's Avatar
rkcnb
10th Gear
EV cables? What are you referring to? Where did they end up finding the leak?
Old Jan 12, 2024 | 06:41 AM
Bgw70's Avatar
Bgw70
Veteran: Air Force
i am guessing the small vent tube, maybe 95337-06006, but who knows.
https://www.megazip.net/zapchasti-dl...tube-17829142#
Old Jan 14, 2024 | 07:30 AM
DshngDaryl's Avatar
DshngDaryl
That explains the half empty part of the problem.
And the rodent chewing the toughest hose to replace also makes sense. Murphy's Law says that's where they are going to chew, never in the easy to access middle of the wire.
Old Jan 15, 2024 | 12:54 PM
Wilson2000's Avatar
Wilson2000
For once, I'm glad we have a bunch of feral cats in the neighborhood! These f-ing chew-happy rodents are costing vehicle owners a heap of money!
Dan300
May 9, 2025 12:44 PM
DONT SLEEP
Mar 12, 2019 05:46 AM
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
GrnEyeDog
Jun 19, 2017 12:49 PM
strad
RX - 1st Gen (1999-2003)
Jun 5, 2010 04:36 PM
