Trouble after trickle charge
Thanks in advance.
With the top, ensure the cover in the trunk is fully seated in the side holder slots.
If the key still starts the car but the buttons don't work, it could be the FOB's battery. If that doesn't fix it, try the key FOB transmitter programming procedure. There iare a few posts about this. The procedure is timing sensitive so it might take a few tries to get right.
The cover is properly seated, and the fob batteries are good. I will try searching out other resetting procedures, but the one I tried (it involved pressing the lock/unlock button on the driver's door multiple times) did not work.
Thanks again.
The receiver for the keyfob is built into your rear view mirror. You can try getting real close to the mirror and see if it works. If it does, then it is most likely your fob batteries.
If not,you probably need to program your fobs. I know you said you tried, but..
Are these the instructions you followed?
Prepare Vehicle for Programming
With the key OUT of the Ignition, OPEN and UNLOCK the Driver’s door.Enter Programming Mode – Step 1
INSERT key into Ignition (Do NOT turn it) and REMOVE key.Enter Programming Mode – Step 2
PERFORM the following steps WITHIN 40 seconds:
a. Using the power lock switch on the driver’s door, perform 5 lock/unlock cycles starting with lock. Use an even pace and try to go about one cycle per second (1 Cycle = 1 lock and 1 unlock).
b. CLOSE then OPEN Driver’s door.Enter Programming Mode – Step 3
b. INSERT key into Ignition.
c. TURN ignition to ON (Do NOT Start) then back to OFF.
DO this ONCE to retain existing remotes programmed.
DO this TWICE to ERASE all existing remotes programmed and ADD NEW remote.
DO this THREE times to CHECK how many remotes are programmed to the vehicle.
DO this FIVE times to ERASE all existing remotes programmed.
d. REMOVE key from Ignition.Enter Programming Mode – Step 4
WITHIN 3 seconds the Power Door Locks should cycle LOCK/UNLOCK to signal successful entry into Programming Mode.Program Remote(s)
a. PRESS the LOCK and UNLOCK buttons on the remote simultaneously for 1 second.
b. PRESS and HOLD the LOCK button for 2 seconds. The Door Locks will cycle LOCK/UNLOCK to indicate successful programming of the remote.Program Additional Remote(s)
REPEAT Steps 6a and 6b for any additional remotes to be programmed.EXIT Programming Mode
CLOSE Driver’s Door to EXIT Programming Mode.Test Remote(s)
TEST all remotes. Programming is complete.
