SC400 Audio issues....
Old Jan 27, 2010 | 09:27 AM
T5258's Avatar
T5258
Default SC400 Audio issues....
Ok, my dad has a 95 SC400 with the Nakakmichi system....the radio works fine & the cd changer (other than skipping bad) works fine as well...the problem is (I think) the amp. When the radio is on you get great sound from the right front speakers & some bass from the woofer in the ctr rear & THAT'S IT. I checked the connector in the rt rear where the phone would have been mounted & found some corrosion & a burn hole thru the plastic housing of the connector, but if I'm not mistaken, that only acts as a jumper when there is no phone installed, so I connected the blue & green wires from that connector only w/no change...in fact it doesn't matter if that connector is connected or not, the sound thru the right front & woofer doesn't change at all....so I guess my question is: Is the amp my next item to check, & is there an easy way to check it?? My dad wants to be sure the amp is crap before chasing one down on ebay & finding out it isn't the problem.....
Old Jan 27, 2010 | 10:36 AM
Teal Sc400's Avatar
Teal Sc400
T5258, I bet on blown speakers....follow these steps to confirm, if speakers are blown?
https://www.clublexus.com/forums/lex...tml#post802171
forgot the rear
http://us.lexusownersclub.com/forums...=rear+speakers
picodroid
Apr 22, 2015 02:20 AM
SC400-V8
Jul 9, 2008 10:57 AM
LexChamp
Jun 29, 2008 04:13 PM
david4laug
Dec 11, 2005 10:38 PM
DlaxMan3
Apr 4, 2005 03:15 PM
