slow windows +++ needs full voltage +12v to speed up
Old Jan 24, 2023 | 05:20 PM
ESCEE400's Avatar
ESCEE400
Default slow windows +++ needs full voltage +12v to speed up
When I was tinkering around with my windows I noticed when I was testing them that if I applied a full 12v to the motor it would roll up and down at regular speed and the motor is quite strong as you could feel the torque when you started it up or down. So I know that they aren't hindered or dirty and the motor (regulators) work just fine.
Then I plug it back in the harness and test it but then they barely move but if you hold them long enough they will eventually close or open all the way. Closing is excruciatingly slow and opening is of course a bit more bearable.
Is there a way to re-wire the window motors to use the full 12v from the battery instead of through the ignition switch? I think it's not getting the full 12v through the ACC setting for some reason and so the windows operate very slowly.
Old Jan 25, 2023 | 05:37 AM
Bimmerbill's Avatar
Bimmerbill
I would love to see an answer to this question also.
Bill
Old Jan 26, 2023 | 11:45 AM
Photon440's Avatar
Photon440
Have you measured the voltage going to the window motor as supplied by the usual wiring? Perhaps contacts are dirty? I haven't looked at the wiring diagram but many cars use a solenoid for the power windows so the power isn't actually routed through the ignition switch anyway; it should be getting power sourced from the battery.
Old Jan 27, 2023 | 12:57 AM
ESCEE400's Avatar
ESCEE400
It can’t be coming directly from the battery because something has to cut the power when you remove the key
Old Jan 28, 2023 | 05:10 PM
pishta's Avatar
pishta
Check the guide pins, ie lube them. You can always check the voltage on the harness with a DMM while your rolling the windows up. That worm drive motor is strong, it ripped the rubber insulator puck apart on mine when the lower guide pin came loose and the window was binding.
Old Jan 29, 2023 | 08:01 AM
t2d2's Avatar
t2d2
Originally Posted by pishta
Check the guide pins, ie lube them. [snip] That worm drive motor is strong, it ripped the rubber insulator puck apart on mine when the lower guide pin came loose and the window was binding.
What are the guide pins? I can't picture what component you're referring to.
Old Jan 30, 2023 | 11:14 AM
ESCEE400's Avatar
ESCEE400
Do you have a picture? I also have a hard time knowing where to look
Old Feb 6, 2023 | 07:09 AM
Photon440's Avatar
Photon440
No, not DIRECTLY from the battery, but a solenoid means that power is switched from the battery rather than all going through the ignition lock circuit.
Sorry, when I said solenoid, I meant 'relay'.
Old Feb 8, 2023 | 07:33 PM
00goobs's Avatar
00goobs
gds112266
Jul 15, 2012 07:34 PM
NoLongerA13bFan
Nov 7, 2008 06:57 PM
bzubke1
Oct 8, 2008 08:47 PM
amiricon
RX - 1st Gen (1999-2003)
May 24, 2007 09:12 AM
Stub333
Sep 2, 2005 05:16 PM
