Immobilizer?
Old Jan 11, 2023 | 01:58 PM
666jame5's Avatar
666jame5
10th Gear
Default Immobilizer?
This is the key
Does anyone know if this 97 sc400 has an immobilizer? This is all i pulled out and it just looks to be an led. Btw, does anyone know what that black box with the yellow and brown wire is?
Old Jan 11, 2023 | 04:09 PM
Arsenii's Avatar
Arsenii
Hello,
No, your car is not equipped with Immobilizer, the key is flat and there is no coil on the Ignition Switch.
As for the box, I presume you mean the component in the Second picture on the Top Left, it is an Interior Temperature Sensor for the Climate Control, a vital component for the proper operation of the system, make sure to treat it with care and not touch the probe on the inside as it is very delicate and it can distort the readings.
Hope this helps and best of luck!
Old Jan 11, 2023 | 05:35 PM
666jame5's Avatar
666jame5
10th Gear
Originally Posted by Arsenii
Hello,
ok thanks I had some clues i just wanted to verify.
Margate330
Feb 13, 2022 07:45 PM
dickn49
Apr 25, 2015 08:34 PM
bfigard
May 16, 2011 04:39 AM
Tymboo
Mar 9, 2006 04:38 AM
3rdelement
Oct 12, 2005 11:11 AM
