brake problem..
Old Oct 9, 2003 | 01:16 AM
Lexs400's Avatar
Lexs400
Default brake problem..
Guys,
I had posted this in the LS forum with little response, therefore I'm posting it here as well.
It's a 93 LS400 with 60K miles. I've had it since it had 40K and I'm the second owner.
A few months ago it developed a wierd brake problem. The pedal travel increased by twice as much as it used to. It's intermittent meaning while driving the pedal would be perfectly fine but the next time you're thinking of applying brakes the pedal would've travelled down. During stop and go driving it's not a pleasant situation. More over at times when the pedal travel increases the pedal feels spongy as well. The pedal seems to have a mind of it's own where it fixes itself back to normal without any reason.
I've taken the car to the local lexus dealer and at this point they've done the following :
1. replaced master cylinder
2. replced brake booster
3. bled the system three times already, replaced the brake fluid with new.
4. checked the callipers and lubricated them.
5. checked all the rotors and brake pads.
After all that work and 2000dollars, the problem is still there. The dealer at this point has given up and claims that it is normal for this model car. I do not agree with that statement since i've owned a smiliar model in the past and it did not have the same problem.
Any suggestions will be appreciated. !
Old Oct 9, 2003 | 03:28 AM
Lexs400's Avatar
Lexs400
No I didn't but the other car I had never had the steel lines either.
I have another question related to this, I'm thinking the only thing that has not been thought of is the pressure buildup system that is connected to the brake booster/master cylinder.
Could someone please tell me where the brake sytem gets it's pressure after everytime the brake pedal is pressed and released ?
thanks.
Old Oct 9, 2003 | 10:14 AM
Nick T's Avatar
Nick T
Lexs400,
Pull and regrease the caliper pins, you might want to buy new o-rings for the pins also. Hopefully the pins are not too badly stuck and can be removed without twisting. If they are stuck, you will have to twist them off and get new pins.
Luck
itsmike177
IS F (2008-2014)
May 5, 2014 04:32 PM
Lexus082
Jun 21, 2011 05:39 PM
gcam77
Suspension and Brakes
Feb 6, 2008 08:53 PM
Lexs400
26
Apr 1, 2004 01:56 PM
Lexs400
Maintenance
Oct 9, 2003 10:19 AM
