EGR delete vacuum routing for N/A
Old Nov 25, 2021 | 10:41 PM
Nine3SC's Avatar
Nine3SC
Default EGR delete vacuum routing for N/A
Hello everyone.
i'm doing this small write up for anyone having idle surge and or low idle and hesitation after EGR delete on a N/A 2JZ-GE.
The vacuum routing is pretty much the same as what others have said on a few threads.
What i did was kept the actuator under the intake hooked up to it's vsv and vacuum tank & that alone greatly improved throttle response. I also re-routed the throttle opener vacuum line to the vacuum hardline above the iacv and that seemed to cure my low idle & hesitation issues all together.
This may not work for you but this fixed all my idle issues after fully removing & blocking off the EGR.
I hope this information can be of help to someone.
Old Dec 4, 2021 | 06:01 PM
GAsc300's Avatar
GAsc300
Thanks Nine3SC for the vacuum diagram.
ive had egr cel for long time with no engine performance issues until recently. Now have hesitation at idle and roughness. Access was tough but Got the dang thing off this weekend and am soaking egr and egr pipe in throttle body cleaner, hoping that’ll set it straight. EGR block off a few steps away if needed. Thanks for write up. I’ve got ‘93 sc300.
Old Mar 23, 2026 | 09:09 AM
nesoga's Avatar
nesoga
6th Gear
Very late to the thread, but I am doing egr delete very very soon. Thank you for this simplified diagram. BUT, anyone looking to take off to do work OR delete EGR, make sure to have 3 or 4 long extensions and 2 swivel sockets! It pops out near the slave cylinder (mine is manual), but the super snake you have created will greatly ease the process! Hope this helps.
But I have a question: what resistors are needed?
mishkinm5
IS F (2008-2014)
25
Jun 6, 2018 09:24 PM
1JZPWRD
Apr 18, 2016 03:10 AM
mk4r34
Apr 23, 2013 02:16 PM
