Kick down cable location
Old Aug 30, 2021 | 12:13 AM
SC400916's Avatar
SC400916
2nd gear
Default Kick down cable location
MY 93 sc400 isnt kicking down into passing gear what can i do to fix this problem
Old Sep 3, 2021 | 11:22 PM
hippopotam's Avatar
hippopotam
The trans kickdown cable runs from the engine bay down to drivers side of the transmission. It is fairly thick and noticeable when you’re under there. You’ll have to take off the TRAC cover, there are two cables there. One goes into your firewall and is the throttle cable, the other goes down behind the engine. The one that goes down is the kickdown cable. It is clipped to the car and the engine in a couple places. Kind of a ***** to get out. Check if it’s connected but I doubt this would come loose or wear out. Seemed pretty sturdy when I took mine out.
There are sensors that can cause the car to not kickdown, I believe. It could also be a faulty kickdown switch, the pad is quite low and you really have to mash the pedal to activate it. Good luck!
Old Sep 4, 2021 | 06:42 AM
scsexy's Avatar
scsexy
good luck figuring it out sc300s don't have a kickdown cable
93sc400970
Nov 24, 2019 07:30 PM
jcdickson1
May 12, 2019 06:41 PM
brad11140
Feb 28, 2014 01:10 AM
