Subframe and diff bolts
Mainly talking about this rusted part that has an arrow. Is this like a washer attached to the bolt and if not will it be re used if I install poly bushings.
I often soak rusty parts in Evapo-Rust then paint with
The lower 'washers' or cups are to be re-used with poly diff bushings. As per repair manual, some cars have washers/shims from the factory above the stock bushings, other do not. Critical to driveline alignment that you reinstall them with the new bushes if they are present.
Differential Ear Bolts: 90105-12218 x 2 bolts, 108lb/ft
Rear Subframe Bolts: 90119-10679 x 8 bolts, 43lb/ft
Front Subframe Bolts: 52285-50011 x 2 bolts, 129lb/ft
"HINT: Some vehicles have the adjusting shim for adjusting the
propeller shaft joint angle installed on top of the upper
mount stopper. Adjusting shim is not always as it is used upon need.
Install the upper mount stopper on the differential carrier.
HINT:
On vehicles with the adjusting shim installed on top of
the mount upper stopper, install that adjusting shim"
Relevant manual section:
https://zinref.ru/avtomobili/Lexus/2...nglish/804.htm
As everyone above has said, replace any of the bolts and other non-rubber parts with OEM if necessary. Also as an alternative to Evap-O-Rust I also recommend Metal Rescue concentrate. I've used that stuff to de-rust many OEM parts that are cast iron and steel. Also bolts, nuts, washers, a ceramic valve with rust on its surface... everything. It so far has not threatened any threads of bolts or threaded holes in various iron and steel parts.
I prime and paint most of these things in appropriately temperature rated VHT spray paints (because VHT spray paints are durable and cheap). For anything heavy duty like a rear differential's iron housing I'll use POR-15 (with a respirator mask) after a lot of careful masking of bolts and areas that need later separation.
I don't think those bolts will go out of production. They probably cross-reference to more Toyota/Lexus vehicles than the SC, Soarer and MKIV Supra. Other much more very SC-specific OEM parts are often what are in danger of being discontinued.
Billy, if you're going to remove that rear differential to replace the rubber bushings with polyurethane you might as well give it a repaint! I used POR-15's de-rusting spray per their instructions to get the surface back to mostly un-oxidized iron before washing it off, drying with a hair dryer and doing some careful masking with painter's tape (over any bolts and the rear aluminum cover). One little can of the actual POR-15 paint with a one-time-use paintbrush over a use shipping pallet is all it took me to do it.
