1995 Sc400 .Changed Ecu Now Getting Spark.
Old Mar 22, 2021 | 01:25 PM
095sc400's Avatar
095sc400
Default 1995 Sc400 .Changed Ecu Now Getting Spark.
I ChangedEcu Now Car Gets Spark.But Still Won’t Start Up .Car Sounds Like It Wants To Start Up Now But Just Won’t .It’s Getting Spark To The Plugs But Now What Should I Check ?Could It Be Fuel Related Problems Now ?
Edit
Old Mar 22, 2021 | 05:15 PM
Brownd3max's Avatar
Brownd3max
Well, if you know it's getting spark, that leaves just the fuel. If you pump the gas pedal while cranking it over, can you smell gas anywhere, like at the tailpipe?
Old Mar 22, 2021 | 07:16 PM
095sc400's Avatar
095sc400
I Was Able To Smell Gas While Sitting Inside The Car
Old Mar 22, 2021 | 07:23 PM
Brownd3max's Avatar
Brownd3max
OK, getting spark and fuel- if it's occasionally catching on a cylinder or two but stumbling on itself, I would suspect a timing issue. Other than not actually starting, does it crank over at a continuous steady speed?
Old Mar 22, 2021 | 07:32 PM
Tallyhoe's Avatar
Tallyhoe
Try disconnecting the battery for about a minute and reconnect it. See if that helps.
Old Mar 23, 2021 | 02:36 AM
095sc400's Avatar
095sc400
Yeah It Cranks Over At A Steady Speed.The Car Sat For About 3 Years Though
Old Mar 23, 2021 | 02:43 AM
095sc400's Avatar
095sc400
Thanks I’ll Try That
Old Mar 23, 2021 | 08:21 AM
Brownd3max's Avatar
Brownd3max
^^^^^ what Tallyhoe said... Also, is the key you're using a factory "master"? I've heard some aftermarket keys can cause these problems.
Old Mar 23, 2021 | 01:42 PM
095sc400's Avatar
095sc400
I Have An Aftermarket Key ,Nd When I Turn it Over The Ignition Gets Stuck As Well And Won’t Turn Back To The Off Position Unless I Disconnect The Battery .Maybe That Could Be It ?
Old Mar 23, 2021 | 04:34 PM
Brownd3max's Avatar
Brownd3max
I'm afraid I'm personally gonna have to "tap-out" at this point, as there seems to be maybe a couple things going on- I dunno, but Good Luck to you Sir...
Old Mar 23, 2021 | 04:40 PM
Tallyhoe's Avatar
Tallyhoe
Have you tried pushing the shift lever forward? I gave mine a love tap 1 time and it started because it refusing to start...
Old Mar 23, 2021 | 04:50 PM
scsexy's Avatar
scsexy
is the fuel from 3 years ago? if so then the gas is bad and thats why it wont start.
it sounds like the ignition is jerry rigged or something is off. You should be able to turn the key freely on and off any time
Look into a new lock cylinder and some good gas is my quick guess
Old Mar 23, 2021 | 06:20 PM
095sc400's Avatar
095sc400
I’ll Try That Tomorrow Thanks
Old Mar 23, 2021 | 06:23 PM
095sc400's Avatar
095sc400
Tank Was Dry Almost .Nd Thanks For The Info
bubbadog
Mar 22, 2021 03:09 PM
Mar 22, 2021 03:07 PM
TensorWorl
Feb 21, 2018 12:53 PM
1SICSC4
May 17, 2011 08:57 PM
