Window regulator fix for Sc models
Old Feb 11, 2005 | 11:42 PM
  #76
PERRYinLA's Avatar
PERRYinLA
I have not had any problems (knock on wood) with my window, so I am not as familiar with this issue as you all seem to be, but it seems that a small cable ferrule (like the one pictured, left) added against each side of the plastic block might help absorb some of the stress.
Old Feb 12, 2005 | 03:00 AM
  #77
twylie's Avatar
twylie
Originally Posted by Deceptik1
Mine was broken in two places also and I changed mine recently. When you get the new regulator all you have to do is unbolt the two screws and take off the spool cover from the motor and then slide the new one in. Your new regulator should come with a new spool cover as Toyota changed the design of the spool cover for some reason.
Excellent! I was hoping it was going to be as simple as that, but was curious as to what I was in for.
Thanks again.
-twylie
Old Feb 17, 2005 | 01:18 PM
  #78
PERRYinLA's Avatar
PERRYinLA
Mine still has not failed (still knocking on wood), but my friend's SC window regulator failed so I had a chance to try out the procedure discussed in this thread. That thin flat outer 14 mm bolt (a 15 mm wrench will work, as will a 5/8" wrench, but it's a 14 mm square head) is very hard to get a grip on, and I had more success grabbing the inner circular "nut" (seen on the left in the pic below) with a pair of vise grips.
If I had access to a grinder, I would have taken a piece of pipe and ground out 4 little pegs to make a handy tool that I could insert into the 4 holes - that would have helped. But in any case, once those darn fasteners are removed, don't put them back!
Since it is possible you may someday be back in there, don't struggle with those fasteners ever again! Go to a hardware store and get some normal fasteners (and some wide washers, to spread the load over a wide area of the glass) and kiss those nuisances goodbye! The re-assembly, and any subsequent servicing of the window regulator goes so much quicker once those fasteners-from-hell are out of the picture.
Old Feb 17, 2005 | 01:30 PM
  #79
rhubarb999's Avatar
rhubarb999
I had no problems with the flat bolts .. had them off in 2 minutes. Now, getting the new regulator back in the door .. that was a bit of a challenge.
Old Feb 17, 2005 | 09:05 PM
  #80
Deceptik1's Avatar
Deceptik1
Unfortunately the cable has the metal piece located inside the plastic block so a washer wouldn't help.
Old Feb 17, 2005 | 11:16 PM
  #81
PERRYinLA's Avatar
PERRYinLA
Default I'm talking about a ferrule, not a washer
And unfortunately I didn't find a diagram on the internet that showed more accurately what I was talking about, so the washer reference in the diagram confused you. I'll eventually find a better one to post.
Old Mar 25, 2005 | 07:38 PM
  #82
lexsc492's Avatar
lexsc492
Default =
so how are the windows working with the repairs. still successful?
Old Mar 26, 2005 | 03:53 AM
  #83
Deceptik1's Avatar
Deceptik1
I get what you mean now. The ferrule you're reffering to supports the plastic piece on either side and lessens the strain on the center piece inside the plastic. Where could I get some ferrules as this is the first time I have ever heard of them?
Thanks,
Alvin
Old Mar 26, 2005 | 09:22 AM
  #84
L. L. S.'s Avatar
L. L. S.
Former Sponsor
From the date of my original post to now, still perfect
Old Mar 28, 2005 | 12:54 PM
  #85
aasc300's Avatar
aasc300
I just ordered my Drivers window regulator new from lexus for $92 Woot Woot!!!!!
How hard is it to swap just the regulator?
Old Mar 28, 2005 | 01:22 PM
  #86
hotttoddie's Avatar
hotttoddie
Default PDF doc for 1995 Sc300 door
In case youall want this.
http://todd.gatorline.com/1995SC300Door.pdf
keep in mind is for a 95 - but all should be still basically same
Old Apr 19, 2005 | 01:13 AM
  #87
Jeffharper's Avatar
Jeffharper
Here is the Aussie way to actually remove the regulator from the vehicle.
http://reepa.com/windowreg.php
This link is new and may be altered accordingly as we learn more.
Jeff
www.f1kits.com
Old Apr 19, 2005 | 01:20 AM
  #88
Tryk's Avatar
Tryk
Can you share the part number with the rest of us? That would be swell
Old Apr 19, 2005 | 04:18 AM
  #89
aasc300's Avatar
aasc300
One of my techs here at the shop charged me $20 to put it in and it works great!
Old Apr 19, 2005 | 11:58 AM
  #90
aasc300's Avatar
aasc300
Ill have to try to find my paperwork to get the part number. I got it from my buddy the Parts magaer at a local Lexus dealership
The Lexus part number is 69802-24033
