Flashing AC Light
Any help or assistance is greatly appreciated
AC is working
Greg
Also, pull codes from the A/C controller. With the car off, hold down the "Push-Auto-Temp" **** and "Recirculate" button at the same time and put the key into the "ON" position (starting the car isn't necessary for this).
You will hear a series of rhythmic beeps and flashes of the A/C controller's LCD panel. If any error codes are present they will flash in front of you with a number representation. These codes are not the same as your Check Engine CEL codes-- the A/C controller error codes are their own thing.
A chart of the possible codes is in this thread:
https://www.clublexus.com/forums/per...eed-codes.html
Just to rule it out, A/C Code 21 (Solar Sensor) is almost certain to show up at dusk, at night or in any enclosed garage where the Solar Sensor will not receive direct sunlight. A high powered flashlight is probably enough to give that sensor what it wants to see as a test, fyi. I digress... just mentioning this to say you can disregard it 99% of the time (unless your Solar Sensor really has gone bad... which it almost never does).
If the alternator is in good working order following testing so that it has been ruled out then the A/C Code test should point you to or close to the issue in the system.
Reading THIS multiple page thread from a Toyota forum may help.
This video shows you what the A/C Magnetic Clutch relay looks like and how easy it is to replace.
Battery test 12.5 at rest not started in 3 days 13.9 car running at reving@ 1000rpm AC Diagnostic test done inside
code 21 & 42
21 no cercern because im in garage other is servo motor/ vent door
Ive decided to ad the voltmeter so when it occurs again I have some indication .
