Electronic issues galore (solved)
Old Feb 1, 2019 | 05:37 PM
Palmdale's Avatar
Palmdale
Default Electronic issues galore (solved)
Alright y'all......yes I'm country as ****. Ive Been skimming through these threads and noticed a ton of people with electrical problems. Dimming headlights when accelerating, windows lowering slowly, gauges dimming etc........
Ive had these same issues and have replaced multiple components and fuses til ive pretty much went insane.
Before you start searching out all of your wires within the loom. Remove and clean or use new hardware on your ground for the battery. Also clean and scratch the surface where your ground is grounded to the frame of the car.
Also add another grounding cable to the terminal. I used an old set of jumper cables, cut the ends off and used a piece of the cable, black, for the next owner.
majority of my probs have ceased and everything works great. Its a quick, easy and cheap DIY. You will be surprised.
leehom
Feb 12, 2015 11:06 PM
MiiK350
Dec 9, 2010 11:57 AM
scfocus
Dec 23, 2009 05:11 PM
Elite
Sep 29, 2007 07:04 PM
starkg
Nov 5, 2006 02:06 PM
