Radio Knob Question
After leaving work today, I went to the car and tried to turn off my radio and the **** no longer turns off the radio?? The temp. **** still works and seems almost like it is spring loaded, does anyone here know what I need to do to fix my raio ****? It will still turn the vol. up and down but no longer and I able to push the **** and have it shut off. Please help.
That push button would be a switch. It can be pulled out - the button cap itself that is. The console surround removes also with some careful prying. Then you will have access to what you need to troubleshoot it. Possibly, the switch is bad or simply a connection has worked its way out.
