95 sc300 timing issue
Old Jun 12, 2018 | 10:31 AM
Fozzyb5's Avatar
Fozzyb5
Exclamation 95 sc300 timing issue
So i have a timing issue i went to get it smogged and it failed due to the timing being advanced by 22 degrees so it was at 32 degrees i was able to retract it by 12 degrees leaving it at 20 degrees or so by backing off the distributor but now i still need about 10 degrees so what should i do
Old Jun 13, 2018 | 05:10 PM
timmy0tool's Avatar
timmy0tool
wrong forum, but I can help:
Originally Posted by WadeLovell
Warm up the engine to normal operating temperature.
Jump TE1 and E1 of the DLC1 (under the hood, not in the passenger compartment).
Using a timing light check the timing. It should be 10 degrees +-2 degrees BTDC at idle with the transmission in neutral and all accessories turned off.
Loosen the distributor nut and adjust the timing by turning the distributor until the timing is 10 degrees BTDC.
Tighten the nut to 19 newton meters (about 14 ft lbs).
Remove the jumper from the DLC1.
Further testing:
Check the timing ranges between 7 degrees and 19 degrees BTDC @idle with the transmission in neutral and all accessories turned off. (The manual says "@idle" but I think it should say over the operating range of RPM.) Let us know what you find. Does the timing vary between 7 and 19 degrees BTDC at idle?
Old Jun 14, 2018 | 03:51 PM
shajbot's Avatar
shajbot
It's naturally 10-12 degree BTDC you cannot have a running engine at 0 degree or any ATDC.
Old Jun 25, 2018 | 09:55 AM
Fozzyb5's Avatar
Fozzyb5
Default Great
Thank you so much
chukarhunt
Apr 27, 2018 12:55 PM
Uhhhsc300
Mar 29, 2013 06:13 PM
bighead222
May 26, 2011 03:35 PM
zrs6v4
Oct 7, 2009 06:45 PM
JTJerryls400
Apr 19, 2005 07:35 AM
