basic timing
Old Apr 18, 2005 | 02:05 PM
JTJerryls400's Avatar
JTJerryls400
Default basic timing
looked at service manual and there seems be not possibility to adjust timing advance in my 1994 sc400. Seems to be fixed at 10. Is that correct? Or it is possible some basic timing adjustments?
Thanks
Jerry
Old Apr 18, 2005 | 03:08 PM
/Aerostar\'s Avatar
/Aerostar\
Well on the SC300's, what you do is loosen the distributor mounting bolt, and with the car idling with no accessories turned on, aim the timing light at the mark on the crank and slowly turn the distributor to adjust timing back and forth. Im sure its done the same way on the SC400s
PS. Yes the stock timing is 10 degrees before TDC
Old Apr 19, 2005 | 07:35 AM
JTJerryls400
yes but that is true in sc300 with 2jz engine. But in UZ1 there looks as distributors are not movable (there is no any adjustment) at all. Someone can help?
Jerry
Returd
Jul 19, 2019 07:02 AM
1uzfe4147
Oct 20, 2010 03:56 PM
shajbot
Jul 13, 2009 08:29 PM
SLEXC400
Maintenance
Jan 12, 2008 11:58 AM
gserep1
Maintenance
Feb 26, 2007 12:03 PM
