Lower control Arm bushing stopper question
Old Mar 27, 2018 | 05:20 PM
xkazman's Avatar
xkazman
Default Lower control Arm bushing stopper question
Just when I'm about complete with replacing my front lower control arms, I realize the passenger side has an extra piece that I didn't install on the driver side. After some brief research, I found it to be a bushing stopper (part below highlighted in green). Do you guys know if this part is necessary for our lower control arms?
If necessary, what is the best way to lower the bolt ends of the LCA without removing everything. I just need clearance to slip the stopper in.
Side info - I'm using Supra LCA on My SC not pushed in bushings. Also, I didn't see the stopper on the driver side since it was destroyed upon removal - the bolt was seized and had to saw it off.
The part is highlighted in green
Old Mar 28, 2018 | 05:40 PM
Returd's Avatar
Returd
failing to use the piece will introduce movement (bad).
put a jack under the ball joint end to support and remove both k member end bolts, lower, install and bolt back up.
I'd lather anti seize on the bolt shanks and threads so you won't have to cut next time.
Old Mar 28, 2018 | 07:43 PM
- V -'s Avatar
- V -
well crap, after seeing this post i realized that i didnt install this piece while mounting my arms. I dont even remember seeing them when i took the old once apart. Is there a part number that can be used to purchase these separately?
Old Mar 29, 2018 | 04:52 AM
BlackIRON's Avatar
BlackIRON
depends on the vehicle and year i believe. I removed stock arms from both a 96 and 99 sc3 and have not seen this hardware yet.
Old Apr 2, 2018 | 10:23 AM
xkazman's Avatar
xkazman
I did exactly this and worked great! Thanks!
Old Apr 2, 2018 | 10:24 AM
xkazman's Avatar
xkazman
This is the part# 48657-24020 - Stopper Front Lower Arm
I ordered online from McGeorge Toyota - I found to be the cheapest OEM parts.
gookies
RX - 1st Gen (1999-2003)
Nov 4, 2018 08:58 PM
Oldguys
Jul 12, 2016 01:43 PM
Farino81
May 27, 2009 05:49 PM
sphy1005
Dec 29, 2005 07:15 PM
KrochRoket
Oct 20, 2003 12:29 AM
