Battery Drain
Old Jan 3, 2018 | 01:31 PM
mrmj2u's Avatar
mrmj2u
Default Battery Drain
Hey guys, I'm trying to troubleshoot a battery drain issue. I was wondering if someone would check the amp draw from the alt-sencing fuse when the car is turned completely off??
I'm seeing ~.05-.07 ma from that fuse location when the car is completely off.
Thanks in advance
Old Jan 3, 2018 | 02:03 PM
logix7's Avatar
logix7
i typically check drain with an amp clamp around the negative cable with the doors locked and hood latch "latched" so the car thinks the alarm is set....wait 15 min and check
Old Jan 5, 2018 | 09:43 AM
RXRodger's Avatar
RXRodger
Sounds like he already has that covered, he just needs somebody to check the one circuit drain. I'll try to get it tonight if noone gets it before then.
Old Jan 5, 2018 | 10:55 AM
mrmj2u's Avatar
mrmj2u
That is correct.
Thanks for your help.
Old Jan 5, 2018 | 08:09 PM
RXRodger's Avatar
RXRodger
Originally Posted by mrmj2u
That is correct.
Which fuse is it, I am not sure from your description.
Old Jan 5, 2018 | 08:16 PM
mrmj2u's Avatar
mrmj2u
Here is a diagram.
Old Jan 6, 2018 | 08:11 AM
Savager's Avatar
Savager
Check both beauty car mirrors. In my case one light was on all the time. Might be the same for you
LSwaff
Jun 11, 2019 09:43 AM
maorsela
RX - 1st Gen (1999-2003)
15
May 1, 2018 12:45 PM
SABIR
Jul 21, 2016 12:34 AM
187
Jan 2, 2015 02:25 PM
LexXxtacy
Nov 26, 2012 05:02 AM
