1997 vs 1998
so in July just like 100,000's of other people my beautiful 2002 is300 was destroyed by hurricane Harvey in Houston Texas and I'm in the market for another 90's era Lexus because they are just the freaking best.
ive decided I would really like an sc400 simply for the bulletproof v8 since I already had the 2jzGE but there's a problem, I would love to have a 1998 sc400 for the vvti and 290hp and the 5 speed manual shifters that my is300 had but they are Just so Hard to find and can't find hardly any even looking outside of Texas but I can find a bunch of 97-
so the debate is here, should I wait save up more money and just hold out looking for an sc400 98' or would it be just as good going with a clean 97 sc400 with 260 HP no vvti but have intakes exhaust and other mods that get me back up to the power I was missing without compromising reliability? Would having a 97 with a few mods be just as fun as a 98 sc400? Would I really notice the lack of the VVti? If so what mods would you suggest for an amateur mechanic? I'm really stuck wish there were just more 98's out there. LMK
For a stock SC400 I'd also recommend seeking out a 1998-2000 models. The last two years are the rarest though.
For 1998's the steering wheel can always be updated to another compatible Toyota/Lexus unit provided the airbag adaptor wires are still available for the later type wheels. A factory style Homelink visor module, if you really want one, can also be DIY added to a non-Homelink SC visor just like the ones on '99-'00's got. It just takes a little careful work. The raw modules are available on ebay. Power gets drawn from the vanity light wiring in the visor. I did this to my 1993 and it works and looks like it came that way from Lexus.
The earlier non-VVTi SC400's are just as bulletproof but with less power as you know. If emission testing isn't a hassle in your area you could also do worse than getting a 1992-1997 SC400 in good shape, keep the engine well maintained and stock and make your only other major change to it a manual transmission swap (usually a W58). Being in college and on a budget, however, even that kind of project may not be advisable until you're in a more stable financial position.
It is not quite as many unpredictable and precarious variables as is any turbo JZ engine project in an SC on a tight minimal budget. Supercharging a 1992-1997 1UZ-FE V8 is possible, usually with a fully custom Eaton M112 roots blower installation and an upgraded fuel system, but even an NA-T 2JZ-GE build is a more accessible and more widely supported path... and all forms of forced induction on an SC will begin to escalate your budget rather quickly... especially if you do it with a UZ V8 engine (much custom work for a lot of cash to do it right). Also, the 1998-2000 1UZ-FE V8 with 290hp is not a good candidate for forced induction due to the weaker/thinner connecting rods, weaker pistons and weaker ring lands. It is a great bulletproof stock motor however that will last just as long as the 1992-1997 1UZ's.
An SC300 factory 5-speed manual is also a great choice if you really love driving stick. Turbo engines always help change them dramatically but a lot of fun can be had just with the stock engine against a manual transmission. Sans-turbo I'd only recommend swapping in a 4.27 SC300 Auto rear end with an LSD (and a Yellowbox speedo accuracy recalibrator) to help change its acceleration characteristics.
An LSD helps any SC with or without forced induction but you will spend about $1k getting one. And the hard to find Supra Torsens have different characteristics than most aftermarket 2-way LSDs. Add just a bit more to have one installed with the correct final drive ratio you'll need/want.
Any SC benefits from a 1995-2000 LS400 front brake caliper swap. Mild suspension updating and going through any worn suspension components (Daizen steering rack bushings to replace old OEM ones for instance) do a lot to restore anything the suspension has lost due to age.
On a college budget an SC can still be a good and reliable car if it has been maintained well by previous owners. But I would not focus on high horsepower modified examples and just find the stock starting configuration SC that suits you best and only allow yourself a few choice modifications as you own and enjoy it.
A few basic modifications such as the front brakes, an affordable/reasonable updated suspension, wider 17" or 18" wheels with wider good compound summer tires and a basic 4200k plug and play HID upgrade (I recommend this for safety and visibility; a PnP xenondepot Phillips kit is reliable and not expensive) are not going to be out of a reasonable small budget to keep and maintain one of these cars.
A good condition W58 (getting harder to locate now) swap into an pre-1998 or pre-1996 SC400 could also be a nice final finishing touch for those models... but again even that might be pushing too far into project car territory while you're in college even with the swap kits and knowledge base available to do this.
If you very much prefer driving a manual, a stock engine SC300 5-speed is also a great choice which will not require anything major to be changed. They were notably rated .1 seconds faster stock for stock than 92-97 SC400's (C&D clocked SC300 5-speeds at 6.8 seconds in the 90's). Still not "fast" and about the same as your IS 5-speed I think but certainly fun.
Coming full circle, if you're fine with an automatic transmission then a 1998-2000 SC400 would be a fine choice stock for stock apart from an LS400 front brake caliper upgrade.
All in all, there are many options available to you but I would keep it relatively simple to stay somewhat affordable. I do not recommend getting into any turbo setup with a JZ engine right now nor would I recommend getting into the far less supported and pricey territory of supercharging or turbocharging a 1UZ engine.
An SC400's exhaust note, even after only having removed the stock resonators, is very nice
Oh-- exhaust-wise either an SC300 or SC400 does really well with stock-ish looking M2 (aka Manzo) axle back mufflers. Affordable, good quality and very nice sound from either the I6 or V8.
I have a 99 SC400 and it is a blast to drive and super reliable.
Whatever you decide to get good luck with you search.
The UZ is excellent in either form, but mods are a black hole into which vast sums disappear with minimal effect. You're not going to make a 250 hp into 300 hp with a few bolt-ons. Some popular changes add less than 1 hp per $50 spent ($1,000: 20 hp).
If 250 hp isn't fast enough, buy a different car.
