Shifter problem
Old Aug 20, 2017 | 05:23 PM
Christian's Avatar
Christian
Default Shifter problem
Hi,
i have trouble with my automatic shifter.
When I am breaking hard the shifter skips from D to N!!
Any hints what is causing this?
Thanks Christian
Old Aug 20, 2017 | 05:59 PM
BiGEZ's Avatar
BiGEZ
How is your transmission mount? Any vibration when driving? Check you transmission mount and shifter linkage adjustment.
Old Aug 20, 2017 | 09:06 PM
- V -'s Avatar
- V -
could be the solenoid that locks the shifter in place. You can try putting the car in park and then press and release the break pedal repeatedly, if you hear a clicking noise coming from under the shifter it means the solenoid is actuating. Now the lack of the noise could mean that its not working or that its working properly since they only start making noise when they get old so the only real way to check that would be to drop the transmission pan though as the solenoid is in there.
Old Aug 22, 2017 | 01:17 AM
Christian's Avatar
Christian
Hi,
thanks for te hints.
But you can always push the shifter from D to N without pushing the ****, it is just to easy so that it moves by itself under hard breaking.
Christian
g0tem
RC - 1st Gen (2015-present)
Mar 28, 2017 05:24 AM
986ci's
Feb 29, 2012 06:53 AM
Rolex007
IS - 1st Gen (2001-2005)
Apr 27, 2003 07:21 AM
shmelvin
RX - 1st Gen (1999-2003)
Dec 27, 2002 06:49 AM
shmelvin
Maintenance
Dec 26, 2002 11:24 PM
