Door rubs
My driver side door has started to rub against the fender. I heard that the hinge goes bad on our cars because the doors are so heavy. So I called out to the west coast to Tapline auto and found one for $99.00. I just want to check with CL before I spend the money.
Another temp solution, is to loosen up the fender bolts and move the fender slightly more to the front(away from the door). That should give you a little more clearance and piece of mind.
kmartinez1
Mar 17, 2014 03:34 PM
97SC
Dec 19, 2003 02:24 PM
