Burning oil
Old May 22, 2003 | 08:02 PM
lilnard85's Avatar
lilnard85
Default Burning oil
Hey everybody,
i have a 1995 sc400 with 127,227 mile on it . I always take it to the same shop to get the oil changed but today i checked the oil level just to kill time and it was down about one quart of oil. I have a heave foot sometimes once a lil 4bagger comes along but, that is beside the point. i Jus want to know that best way to stop this i was thinging i was goin g to have to get the pistons ring changed or something like that. can someone help me out here
thanks
Old May 22, 2003 | 08:49 PM
RTLEXSC's Avatar
RTLEXSC
Try a little heavier oil,maybe 15-50.If that doesn't do the trick put in a Q of Lucas.
Old May 23, 2003 | 06:15 AM
ChrisK's Avatar
ChrisK
How many miles did you put after the last oil change? Keep in mind that burning some oil is actually normal. Also, did you check if the engine didn't develop a leak somewhere?
If the car is not leaking, you could try to use Auto-rx, which is highly recommended by Bob is the oil guy web site. If you go through the forums on this web site you will see a lot of people who used it with success.
Old May 24, 2003 | 11:41 PM
lilnard85's Avatar
lilnard85
Thanks
im goin to go get my oil changed today and the problem might be that they are not puttin a enough. thanks for al the help.
Old May 30, 2003 | 08:59 AM
abboushi's Avatar
abboushi
i found out the reason my car was burning oil was because my coolant was low. its worth taking a look at
Old May 30, 2003 | 02:14 PM
VSsc400's Avatar
VSsc400
if they used a different brand or type of oil then it will burn oil at a greater rate for about 2 oil changes. Same case if you used oil additive.
amerquresh
May 11, 2012 06:39 PM
Ac93sc
Aug 5, 2007 06:03 PM
rx93
RX - 1st Gen (1999-2003)
25
Dec 24, 2006 10:45 AM
Boz MoN
Mar 29, 2006 02:11 PM
LEXISM
Performance
Jun 9, 2004 10:57 PM
