93 Lexus sc400
Old Aug 1, 2016 | 02:33 PM
tvb74's Avatar
tvb74
Default 93 Lexus sc400
I have a problem with my car. It will not go pass 20 mph. I step on the gas and just stop at 20. I can't get it to go pass 3000 rpm. It just goes back down, I need help. What could be the problem?
Old Aug 1, 2016 | 03:18 PM
t2d2's Avatar
t2d2
Any CELs (Check Engine Light)?
Old Aug 1, 2016 | 03:24 PM
tvb74's Avatar
tvb74
No engine lights on. Just the trac light is on.
Old Aug 2, 2016 | 06:06 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Is the engine response poor?
Old Aug 2, 2016 | 07:06 PM
tvb74's Avatar
tvb74
The engine is good. The engine wants to go but just stops at 20 mph. I get to 2500 rpm and it cuts gas power down 1000rpm. I think it is the throttle sensor or something else.
Old Aug 3, 2016 | 06:54 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Has the ECU been serviced recently? It's a very common failure point on the SC as they get older, because the caps start to leak on the board. About 140 bucks to rebuild.
What has been replaced in effort to correct?
Old Aug 10, 2016 | 07:50 PM
DA51's Avatar
DA51
I bought a 92 SC400 with TRAC in 2001. During the winter my Check TRAC light came on. I took it to the local Lexus Dealer. All SC's with TRAC have a 2nd Throttle position sensor. They replaced the TPS and the Silver cylinder with the rubber hose underneath the Brake Booster area. Cost me about $1000. The TPS for TRAC is the first one on the inlet pipe.
I would check the TPS for TRAC first.
Revhead95
Oct 16, 2013 10:21 AM
Andy16
Dec 26, 2012 03:26 PM
marig
Nov 27, 2012 02:20 PM
jroy3221
Nov 24, 2012 07:24 AM
lisagurl
Mar 5, 2012 04:31 AM
