Need Help!!! Sc 400
Old Dec 25, 2012 | 07:42 PM
Andy16's Avatar
Andy16
Default Need Help!!! Sc 400
i have a 1992 lexus sc400 and was driving home one day and both the check engine light and the traction control turned off and wont come back on which typically happens when the check engine light comes on so i read the codes and it came out a DTC 32 which is a airflow meter signal so im thinking possible MAF sensor cuz it has the typical MAF sensor symptoms like hesitating under a load, stalling right after start up, rough idleing, and hesitating under sudden throttle changes. but i have also been reading around and apparently it could also possibly be a O2 sensor problem? or could i have an entirely diffrent problem that i am not yet aware of so i would appriciate the help if u could
Old Dec 26, 2012 | 03:26 PM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
https://www.clublexus.com/forums/sc-...-93-sc400.html
https://www.clublexus.com/forums/per...-issues-4.html
https://www.clublexus.com/forums/per...ermittent.html
https://www.clublexus.com/forums/per...dle-1uzfe.html
https://www.clublexus.com/forums/sc-...then-dies.html
...and that's just the tip of the iceberg...the issue could be anything of what you mentioned plus more. Make sure to read every thread provided...there are lot's more...search before you....post.
Welcome to CL
Southaven
Jul 8, 2016 07:52 AM
jscoda
GX - 1st Gen (2003-2009)
Oct 9, 2014 03:23 PM
amanda
16
Apr 9, 2012 03:29 PM
johnny1
Jul 26, 2006 04:47 AM
methodmf
Oct 8, 2001 06:09 PM
